Library audio
Robert Olson
olson at mcs.anl.gov
Wed Dec 17 16:09:59 CST 2003
did some tweaking in there today. Notes:
The wiring is as the labels in the config file library-spatialized.apd are
set up. I saved my tuning in library-spatialized-tuned-1217.
Someone should go over the phoenix connectors and doublecheck all the wires
are secure in them. I had a problem where mic 1 was sending noise; touching
the phoenix connector in back brought it back on, so I think there's some
looseness going on.
I changed the label on mic 3 (on the coffee table) to mic 4, as that's
where it's actually attached.
I changed the global gating parameters to disable first mic priority and PA
adaptive. Doing this appears to have cleared the fading audio problem.
--bob
