FW: BOUNCE ag-dev at mcs.anl.gov: Non-member submission from [Hiroyuki Komatsu <komatsu at mcs.anl.gov>]
Hiroyuki Komatsu
komatsu at taiyaki.org
Tue Dec 9 14:22:49 CST 2003
I am already a member of this list. It seems that I have been
registered as <komatsu at taiyaki.org>, not as <komatsu at mcs.anl.gov>.
So I send mails to this list from <komatsu at taiyaki.org> after this.
Hiro
At Tue, 9 Dec 2003 13:56:02 -0600,
Ivan R. Judson wrote:
> Hiro should be on this list.
> --Ivan
> > -----Original Message-----
> > From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov]
> > Sent: Tuesday, December 09, 2003 1:41 PM
> > To: owner-ag-dev at mcs.anl.gov
> > Subject: BOUNCE ag-dev at mcs.anl.gov: Non-member submission
> > From owner-ag-dev at mcs.anl.gov Tue Dec 9 13:40:18 2003
> > Received: from gyokuro.gyokuro.gn.taiyaki.org
> > (float56035.mcs.anl-external.org [140.221.56.35])
> > by mcs.anl.gov (8.11.6/8.9.3) with ESMTP id hB9JeIl17824
> > for <ag-dev at mcs.anl.gov>; Tue, 9 Dec 2003 13:40:18 -0600
> > Received: from gyokuro.gn.taiyaki.org.taiyaki.org (localhost
> > [127.0.0.1])
> > by gyokuro.gyokuro.gn.taiyaki.org (Postfix) with ESMTP
> > id 85C181F5143
> > for <ag-dev at mcs.anl.gov>; Tue, 9 Dec 2003 13:40:09 -0600 (CST)
> > Date: Tue, 09 Dec 2003 13:40:09 -0600
> > Message-ID: <87llplu6ee.wl at gyokuro.gn.taiyaki.org.taiyaki.org>
> > From: Hiroyuki Komatsu <komatsu at mcs.anl.gov>
> > To: ag-dev at mcs.anl.gov
> > Subject: Window Layout Library.
> > User-Agent: Wanderlust/2.9.15 (Unchained Melody) SEMI/1.14.4
> > (Hosorogi) FLIM/1.14.4
> > (=?ISO-8859-4?Q?Kashiharajing=FE-mae?=) APEL/10.4 MULE
> > XEmacs/21.4 (patch 14) (Reasonable Discussion) (i386-debian-linux)
> > MIME-Version: 1.0 (generated by SEMI 1.14.4 - "Hosorogi")
> > Content-Type: text/plain; charset=US-ASCII
> > X-Spam-Status: No, hits=0.0 required=5.0
> > tests=USER_AGENT
> > version=2.55
> > X-Spam-Level:
> > X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
> > My prototype of window layout library is available at
> > <http://www.accessgrid.org/~komatsu/tmp/windowlayout-0.2.0.tar.gz>.
> > This library calculates available spaces from a whole
> > rectangle size (as a display size) and rectangle geometries
> > (x,y,w,h) in the whole rectangle (as window geometries).
> > Though the current version is not enough to use for the
> > autoplace extension of AG, you can build and run a test
> > command like here:
> > ./configure (You need GLib and GTK development environments)
> > make
> > ./src/layout-test
> > For more detail, please read READEME.
> > Hiroyuki Komatsu
