FW: BOUNCE ag-dev at mcs.anl.gov: Non-member submission from [Hiroyuki Komatsu <komatsu at mcs.anl.gov>]
Ivan R. Judson
judson at mcs.anl.gov
Tue Dec 9 13:56:02 CST 2003
Hiro should be on this list.
--Ivan
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov]
> Sent: Tuesday, December 09, 2003 1:41 PM
> To: owner-ag-dev at mcs.anl.gov
> Subject: BOUNCE ag-dev at mcs.anl.gov: Non-member submission
> From owner-ag-dev at mcs.anl.gov Tue Dec 9 13:40:18 2003
> Received: from gyokuro.gyokuro.gn.taiyaki.org
> (float56035.mcs.anl-external.org [140.221.56.35])
> by mcs.anl.gov (8.11.6/8.9.3) with ESMTP id hB9JeIl17824
> for <ag-dev at mcs.anl.gov>; Tue, 9 Dec 2003 13:40:18 -0600
> Received: from gyokuro.gn.taiyaki.org.taiyaki.org (localhost
> [127.0.0.1])
> by gyokuro.gyokuro.gn.taiyaki.org (Postfix) with ESMTP
> id 85C181F5143
> for <ag-dev at mcs.anl.gov>; Tue, 9 Dec 2003 13:40:09 -0600 (CST)
> Date: Tue, 09 Dec 2003 13:40:09 -0600
> Message-ID: <87llplu6ee.wl at gyokuro.gn.taiyaki.org.taiyaki.org>
> From: Hiroyuki Komatsu <komatsu at mcs.anl.gov>
> To: ag-dev at mcs.anl.gov
> Subject: Window Layout Library.
> User-Agent: Wanderlust/2.9.15 (Unchained Melody) SEMI/1.14.4
> (Hosorogi) FLIM/1.14.4
> (=?ISO-8859-4?Q?Kashiharajing=FE-mae?=) APEL/10.4 MULE
> XEmacs/21.4 (patch 14) (Reasonable Discussion) (i386-debian-linux)
> MIME-Version: 1.0 (generated by SEMI 1.14.4 - "Hosorogi")
> Content-Type: text/plain; charset=US-ASCII
> X-Spam-Status: No, hits=0.0 required=5.0
> tests=USER_AGENT
> version=2.55
> X-Spam-Level:
> X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
> My prototype of window layout library is available at
> <http://www.accessgrid.org/~komatsu/tmp/windowlayout-0.2.0.tar.gz>.
> This library calculates available spaces from a whole
> rectangle size (as a display size) and rectangle geometries
> (x,y,w,h) in the whole rectangle (as window geometries).
> Though the current version is not enough to use for the
> autoplace extension of AG, you can build and run a test
> command like here:
> ./configure (You need GLib and GTK development environments)
> make
> ./src/layout-test
> For more detail, please read READEME.
> Hiroyuki Komatsu
