FW: [Pywebsvcs-talk] puzzlement on the recurring problem
Ivan R. Judson
judson at mcs.anl.gov
Fri Dec 5 08:48:40 CST 2003
> -----Original Message-----
> From: pywebsvcs-talk-admin at lists.sourceforge.net
> [mailto:pywebsvcs-talk-admin at lists.sourceforge.net] On Behalf
> Of Warnes, Gregory R
> Sent: Thursday, December 04, 2003 1:52 PM
> To: 'Eric S. Johansson'; pywebsvcs
> Subject: RE: [Pywebsvcs-talk] puzzlement on the recurring problem
> Hi Eric,
> Yes, I've been working on integrating code into SOAPpy that
> will automatically unwrap SOAP objects into basic python
> objects. The code is in CVS and is enabled when
> Config.unwrap_results=1.
> Please give it a try and let me know how it works for you.
> -G
> > From: Eric S. Johansson [mailto:esj at harvee.org]
> > Sent: Thursday, December 04, 2003 2:15 PM
> > To: pywebsvcs
> > Subject: [Pywebsvcs-talk] puzzlement on the recurring problem
> > The last time I query the group about problems with soappy, I got a
> > response which gave me a small type converter to extract data
> > from the
> > return values. Well I came back to the soap interface again to
> > integrate by code and a similar problem shows up.
> > on returning a dictionary, I get:
> > {u'red': 'active'}
> > on returning a dictionary containing lists, I get
> > <SOAPpy.Types.typedArrayType Result at 138143884>
> > the code "simplify" apparently doesn't work with these
> types and I am
> > looking for the correct course of action on how to handle
> these cases
> > both now and in the future.
> > If memory serves, I believe someone put some code to solve these
> > problems into the soappy cvs. If I should just grab a copy
> > of current
> > cvs, let me know and I'll do so.
> > ---eric
> > Speech recognition in use. Incorrect endings, words, and case is
> > closer than it appears
> > This SF.net email is sponsored by: SF.net Giveback Program. Does
> > SourceForge.net help you be more productive? Does it help
> you create
> > better code? SHARE THE LOVE, and help us help YOU! Click Here:
> > http://sourceforge.net/donate/
> > _______________________________________________
> > Pywebsvcs-talk mailing list Pywebsvcs-talk at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/pywebsvcs-talk
> LEGAL NOTICE
> Unless expressly stated otherwise, this message is
> confidential and may be privileged. It is intended for the
> addressee(s) only. Access to this E-mail by anyone else is
> unauthorized. If you are not an addressee, any disclosure or
> copying of the contents of this E-mail or any action taken
> (or not taken) in reliance on it is unauthorized and may be
> unlawful. If you are not an addressee, please inform the
> sender immediately.
> Does SourceForge.net help you be more productive? Does it
> help you create better code? SHARE THE LOVE, and help us
> help YOU! Click Here: http://sourceforge.net/donate/
