FW: updated timer
    Terry Disz
    disz at mcs.anl.gov
    Fri Aug 29 14:34:53 CDT 2003
AG-DEV,
Here is a timer module Rusty and I are using to instrument our code and
find out what is taking how much time.
If anyone  cares to time something, you might be interested in it.
A new version with std deviation is forthcoming, I will post when ready.
Terry
-----Original Message-----
Sent: Thursday, August 28, 2003 10:43 AM
To: desai at mcs.anl.gov; rbutler at mcs.anl.gov; rbutler at mtsu.edu;
disz at mcs.anl.gov; bradshaw at mcs.anl.gov; alusk at uiuc.edu
Subject: updated timer
This version has a check() method to see how much time a running timer
has accumulated (feature requested by Narayan), and raises an exception
if you try to check a timer that is not running.
#!/usr/bin/env python
# A timer class
from time import time
from exceptions import Exception
class timer_exception(Exception):
    pass
class timer:
    def __init__(self,name):
        self.num_intervals = 0
        self.total_time    = 0
        self.name          = name
        self.min           = 1000000
        self.max           = 0
        self.starttime     = -1
    def start(self):
        self.starttime = time()
    def stop(self):
        self.stoptime = time()
        self.new_interval = self.stoptime - self.starttime
        self.total_time += self.new_interval
        self.num_intervals += 1
        self.avg_interval = self.total_time / self.num_intervals
        if self.new_interval < self.min:
            self.min = self.new_interval
        if self.new_interval > self.max:
            self.max = self.new_interval
        self.starttime = -1               # reset
    def check(self):
        if self.starttime == -1:
            raise timer_exception
        else:
            return time() - self.starttime
    def tprint(self):
        print 'statistics for %s timer:' % (self.name)
        print 'total time          = %6.3f seconds' % (self.total_time)
        print 'number of intervals =  %s' % (self.num_intervals)
        print 'average interval    = %6.3f seconds' %
(self.avg_interval)
        print 'max interval        = %6.3f seconds' % (self.max)
        print 'min interval        = %6.3f seconds' % (self.min)
# a test program
if __name__ == '__main__':
    kbd_timer = timer('keyboard')
    for i in range(5):
        kbd_timer.start()
        line = raw_input("Type a line: ")
        kbd_timer.stop()
        print 'Typed %s in %f seconds' % (line, kbd_timer.new_interval)
    kbd_timer.tprint()
