FW: [AG-TECH] Problems with AG2.1 install
    Ivan R. Judson
    judson at mcs.anl.gov
    Mon Aug 18 11:53:27 CDT 2003
Hm.
-_ivan
> -----Original Message-----
> From: Michael Daw [mailto:mike.daw at man.ac.uk]
> Sent: Monday, August 18, 2003 11:33 AM
> To: judson at mcs.anl.gov
> Subject: RE: [AG-TECH] Problems with AG2.1 install
> > This is certificate/globus initialization stuff; I think
> Bob's looking
> > (or can look at this). He'll probably need more information
> to track
> > it down though, do you have a log from the client or server you can
> > send?
> 'Fraid not. Should I be running something to initialise
> globus? I seem to remember the last installation procedure
> (where it wasn't bundled) set it up fine - perhaps install.sh
> is missing this step? I wasn't running the client or server -
> I was setting it up on a new machine and was looking for a
> place to put my certificate.
> However, if I try to run the venues client, it just hangs
> (when the bar is about 9/10ths across!).
> > I'd be happy to help figure out what's going on here, but
> the log that
> > was sent was empty. Can you run the tools in debug mode and send me
> > anything that's coming out in the window you ran them in?  That'll
> > make it possible to track down problems. I suspect it's either
> > initialization or installation things that have bitten you. Are you
> > sure you completely removed the previous software before installing
> > 2.1?
> I removed AGTk 2.0 and WinGlobus (as instructed).
> In venue client debug mode, the command prompt shows the
> following (last page of) output. (I sent it in the error report too):
> No handlers could be found for logger "AG.VenueClient"
> 08/18/03 17:29:19 DEBUG My hostname is phoebe.mvc.mcc.ac.uk
> 08/18/03 17:29:19 DEBUG VerifyExecutionEnvironment: bind to
> local hostname of ph oebe.mvc.mcc.ac.uk succeeds 08/18/03
> 17:29:19 DEBUG userConfigDir: C:\Documents and
> Settings\zzcgumd\Applica tion Data\AccessGrid 08/18/03
> 17:29:19 ERROR exception opening hash C:\Documents and
> Settings\zzcgumd \Application Data\AccessGrid\certRepo\metadata.db
> Traceback (most recent call last):
>   File
> "C:\Python22\Lib\site-packages\AccessGrid\CertificateRepository.py",
> line
>  143, in __init__
>     self.db = bsddb.hashopen(self.dbPath, 'w')
> error: (22, 'Invalid argument')
> 08/18/03 17:29:19 ERROR bin.VenueClient::OnInit:
> WXGUIApplication creation faile d Traceback (most recent call last):
>   File "C:\Program Files\AGTk 2.1\bin\VenueClient.py", line
> 119, in __init__
>     self.app = Toolkit.WXGUIApplication()
>   File "C:\Python22\Lib\site-packages\AccessGrid\Toolkit.py",
> line 141, in __ini t__
>     self.gui)
>   File
> "C:\Python22\Lib\site-packages\AccessGrid\CertificateManager.py",
> line 24
> 1, in __init__
>     create = 0)
>   File
> line
>  156, in __init__
>     os.rename(self.dir, newname)
> OSError: [Errno 13] Permission denied
> > From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
> > Sent: 18 August 2003 15:52
> > To: 'Michael Daw'; 'AG Technical Developers'
> > > Unless I'm doing something stupid (always a distinct
> possibility), I
> > > can see several problems with the new AG2.1 install that
> I'm doing
> > > this week for SC
> > > Global:
> > > 1. The Linux bundle doesn't include rpms for vic or rat (and the
> > > Audio and Video Service rpms fail as a result).
> > Frank reported this as well. It's being fixed as we speak (write).
> > > 2. The Linux install doesn't create a .globus directory for
> > > certificates. (I can't remember how these got created in the
> > > previous install. Maybe I answered the questions wrongly...)
> Bob's looking
> to track
> > send?
> > > 3. There is no icon for Venue Server in Linux on the "Start menu"
> > > (or whatever it's called in Linux).
> > There hasn't ever been a icon for the venue server, perhaps you can
> > file that as a feature request :-).
> > > 4. I can't seem to start anything on my Windows install.
> The Venues
> > > Client stops halfway through starting up and sends an automated
> > > error report (which I sent); the Venue Server rattles the disk a
> > > bit, but otherwise nothing; Manage Venue Server flashes
> up a window
> > > and then fails.
> the log that
> > 2.1?
> > --Ivan
