FW: AG audio
Ivan R. Judson
judson at mcs.anl.gov
Tue Apr 22 12:21:35 CDT 2003
This is very cool; we need to corner bob at the AHM and figure out how to
get this functionality into AG2 since it is one of our feature requests :-)
--Ivan
PS -- just highlighting windows would be good for us for now.
> -----Original Message-----
> From: Robert Putnam [mailto:putnam at tonka.bu.edu]
> Sent: Tuesday, April 22, 2003 12:00 PM
> To: jtvh at bu.edu
> Cc: papka at mcs.anl.gov; glenn at bu.edu; stevens at mcs.anl.gov;
> judson at mcs.anl.gov; disz at mcs.anl.gov
> Subject: Re: AG audio
> Date: Tue, 22 Apr 2003 08:53:12 -0400
> From: Jennifer Teig von Hoffman <jtvh at bu.edu>
> User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1;
> en-US; rv:1.2.1) Gecko/20021130
> X-Accept-Language: en-us, en
> CC: "'Glenn Bresnahan'" <glenn at bu.edu>,
> "Rick L. Stevens" <stevens at mcs.anl.gov>, Ivan Judson
> <judson at mcs.anl.gov>,
> "'Terry Disz'" <disz at mcs.anl.gov>, putnam at bu.edu
> Content-Type: text/plain; charset=us-ascii; format=flowed
> Hi Mike,
> Robert Putnam is developing this, and will be
> demonstrating it next week
> at the AHM. He's currently running this with AG 1.x, but
> developing it
> in such a way that it should be no problem to move it up
> to 2.x once the
> various programming hooks are in place. He's planning to
> eventually rely
> on AG2 authentication services to match vic and rat
> streams appropriately.
> I'm cc-ing him here; Robert, can you say a bit more about it?
> Sure. Here's an abstract, plus a little internal memo I
> wrote about it:
> This is a demonstration of a prototype AG system that
> does left-right
> panning of incoming Rat audio streams to their
> corresponding Vic window
> locations. A modified version of Vic transmits window
> locations to a
> custom software application, which, in turn, issues
> stereo positioning
> commands to a standard (unmodified) Rat. It is hoped
> that the test
> implementation will shed some light on the following
> questions: What are
> the hardware and software requirements of a positional
> audio system?
> What is the impact on system performance (e.g.,
> increased packet loss,
> impaired echo-cancellation, etc.)? Would another
> mechanism, e.g.,
> visually highlighting vic windows, be more effective at
> helping users
> identify the current speaker? Does the system provide
> an increased
> sense of immersion? Does it increase (or decrease)
> intelligibility and
> overall audio quality? Is it distracting? And do the
> benefits of
> positional audio justify the system's increased cost
> and complexity?
> Vic and Rat have a built-in message scheme called the
> "conference bus" or "mbus." Rat uses it to do interprocess
> communication between the user interface and the audio
> engine, but the standard AG Vic pretty much ignores mbus
> messages. My agent uses the mbus to communicate with both
> Vic and Rat.
> When the agent starts up, it reads a little database file
> that has associations between the Vic and Rat capture machines:
> site: Purdue University
> rat_name: Purdue University
> vic_name: Purdue University MAIN
> vic_name: Purdue University PRESENTER
> vic_name: Purdue University AUDIENCE
> As I said at the meeting, I expect that this part of the
> implementation will go away when I use AG 2.0 services to get
> these associations.
> The agent then starts monitoring the stream of messages Rat
> sends from its audio engine to its user interface, including
> periodic (every second or so) updates about the incoming
> audio streams. It puts into a array of structs the names and
> IP addresses of the remote Rats and the local ID that Rat
> uses for them. Here's the current struct definition:
> struct db {
> int site_id;
> char site_name[STANDARD_STRING_LEN];
> char vic_names[MAX_VICS][STANDARD_STRING_LEN];
> char rat_name[STANDARD_STRING_LEN];
> int last_xi;
> int num_vics;
> unsigned int data[3];
> } Db[MAX_SITES];
> My modified Vic puts a message on the mbus whenever the
> operator adjusts a window location. The message contains the
> window XY location (scaled to floats between 0.0 and 1.0) and
> the IP address and name of the remote Vic capture machine.
> The agent reads the message off the mbus and tries to find
> the corresponding rat capture machine, using a heuristic if
> necessary. (Again, this will change in the future.) If
> there's a match, the agent puts a "3D audio" positioning
> command (part of Rat's standard equipment) on the mbus. The
> message contains the local Rat ID for the stream, the azimuth
> (-90 to 90 degrees) and whether to do simple panning or HRTF
> (I'm using the former because I think it sounds better over
> loudspeakers).
> Note that this test implementation is made a little simpler
> because interprocess communication is built into Vic and Rat,
> and they are running on the same machine. If this were a
> more typical AG setup, I'd have to write a little socket code
> for messages between Vic and the agent.
> Robert Putnam
> putnam at bu.edu
> (617) 353-8295
> (P.S. Congrats on such a successful AG retreat!)
> - Jennifer
> Michael E. Papka wrote:
> >Glenn and Jennifer,
> >Can I get more info on this?
> >Enhanced AG Audio
> >- Developing positional audio for the AG
> >- Associate rat and vic streams
> >- Locate vic window on display surface, Uses a modified vic
> >- Send positional audio info to rat, Uses rat 3d audio
> capabilities
> >- Will demonstrate proof of concept at AHM
> >Thanks
> >Mike
