Globus release note
Ti Leggett
leggett at mcs.anl.gov
Fri Apr 4 11:14:19 CST 2003
I've also made some wxGTK rpms because the one's on the web site do not
work by default under rh73. I've updated the web page to reflect these
new rpms and to point to the newer wxPythonGTK as well.
On Fri, 2003-04-04 at 10:33, Ti Leggett wrote:
> Can we get a big note in the release that says, "If you have problems
> with no longer finding your certificates you will need to copy your
> certifactes from the old .globus directory to the new globus directory.
> It can normally be found at
> C:\Documents and Settings\<username>\Application Data\.globus
