Red Hat build tricks and treats
    Ti Leggett
    leggett at mcs.anl.gov
    Fri Apr  4 10:05:04 CST 2003
So here is the short and skinny of RPM building
1) remove any previous cvs checkout
2) checkout the code
3) run the attached script to make the tarball (this will remove the CVS
dirs so the tarball is more appropriate for release so your CVS checkout
will be unusable afterwards)
4) copy the tarball to /usr/src/redhat/SOURCES
5) copy the spec file (AccessGrid/packaging/redhat/AccessGrid.spec) to
/usr/src/redhat/SPECS
6) cd /usr/src/redhat/SPECS
7) run: rpm -ba AccessGrid.spec
That should do it.
Type: text/x-sh
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20030404/b6893132/attachment.sh>
