Configuration Document
Ivan R. Judson
judson at mcs.anl.gov
Tue Apr 1 16:38:39 CST 2003
Is it possible to add two calls:
GetSystemTempDir() and GetUserTempDir()?
These are used by various pieces that need to deal with temporary data.
On linux they should probably both return /tmp, but on windows there are two
temps:
Windows\tmp and Documents and settings\user\temp
--Ivan
> -----Original Message-----
> From: Eric Olson [mailto:eolson at mcs.anl.gov]
> Sent: Tuesday, April 01, 2003 3:04 PM
> To: Ivan R. Judson
> Cc: 'AG Dev'
> Subject: Re: Configuration Document
> Added a small table of paths on each platform, and the environment
> variable that can be used to override them.
> Eric
> On Fri, 28 Mar 2003, Ivan R. Judson wrote:
> > Here's the doc, no interface.
> > -Ivan
