Better log file...
Justin Binns
binns at mcs.anl.gov
Tue Apr 1 14:50:39 CST 2003
Much more concise log file - I just clipped out all the junk at the
beginning. Sorry ;-)
Justin
04/01/03 14:36:15 INFO
04/01/03 14:36:15 INFO --------- START VenueClient
04/01/03 14:36:15 DEBUG Home path is C:\Documents and Settings\Justin\Application Data\.AccessGrid
04/01/03 14:36:15 DEBUG profile exists
04/01/03 14:36:15 DEBUG ----------------Datastore path is C:\Documents and Settings\Justin\Application Data\.AccessGrid\personalDataStore
04/01/03 14:36:15 DEBUG Worker 0 starting
04/01/03 14:36:15 DEBUG Worker 1 starting
04/01/03 14:36:15 DEBUG Worker 2 starting
04/01/03 14:36:15 DEBUG Worker 3 starting
04/01/03 14:36:15 DEBUG Worker 4 starting
04/01/03 14:36:18 DEBUG Creating personal datastore at C:\Documents and Settings\Justin\Application Data\.AccessGrid\personalDataStore using port personalDataStore
04/01/03 14:36:18 DEBUG check for validity
04/01/03 14:36:18 DEBUG start wxApp main loop/thread
04/01/03 14:36:38 INFO Sending data: <AccessGrid.Events.ConnectEvent instance at 0x025628A8>
04/01/03 14:36:38 INFO Sending data: <AccessGrid.Events.HeartbeatEvent instance at 0x02473E28>
04/01/03 14:36:39 DEBUG Go to new venue
04/01/03 14:36:39 DEBUG Is this a server
04/01/03 14:36:39 DEBUG venue url: https://vv2.mcs.anl.gov:9000/Venues/default
04/01/03 14:36:39 DEBUG the handler is valid
04/01/03 14:36:39 DEBUG EVENT- Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
04/01/03 14:36:39 DEBUG Add participants
04/01/03 14:36:39 DEBUG Jeff schwab
04/01/03 14:36:39 DEBUG Chris Willing
04/01/03 14:36:39 DEBUG Sugree Phatanapherom
04/01/03 14:36:39 DEBUG Eric
04/01/03 14:36:39 DEBUG Ivan R. Judson
04/01/03 14:36:39 DEBUG Shawn Davis
04/01/03 14:36:39 DEBUG Brian Corrie (Home)
04/01/03 14:36:39 DEBUG Jeff Schwab
04/01/03 14:36:39 DEBUG Randy Heiland
04/01/03 14:36:39 DEBUG Justin Binns
04/01/03 14:36:39 DEBUG Michael Miller
04/01/03 14:36:39 DEBUG Add data
04/01/03 14:36:39 DEBUG profile.type = 000000f449bbb8f7008c00dd000b0037e13
04/01/03 14:36:39 DEBUG This is personal data
04/01/03 14:36:39 DEBUG RunMe.py
04/01/03 14:36:39 DEBUG homepage[1]
04/01/03 14:36:39 DEBUG Add nodes
04/01/03 14:36:39 DEBUG Vikram Gazula
04/01/03 14:36:39 DEBUG Add exits
04/01/03 14:36:39 DEBUG Secure Room
04/01/03 14:36:40 DEBUG Windmer Room
04/01/03 14:36:40 DEBUG Additional Meeting Room Lobby
04/01/03 14:36:40 DEBUG Institution Lobby
04/01/03 14:36:40 DEBUG Jack Frost Room
04/01/03 14:36:40 DEBUG Test Room
04/01/03 14:36:40 DEBUG Big Horn Room
04/01/03 14:36:40 DEBUG Supercomputing 2002
04/01/03 14:36:40 DEBUG Full Sail Room
04/01/03 14:36:40 DEBUG Lucky Labrador Room
04/01/03 14:36:40 DEBUG Encryption Test Room
04/01/03 14:36:40 DEBUG Bridgeport Room
04/01/03 14:36:40 DEBUG Screening Room
04/01/03 14:36:40 DEBUG Set text location and address bar
04/01/03 14:36:40 DEBUG VenueClientUIClasses.py: VenueClientUIClasses.py: Set text location host:vv2.mcs.anl.gov, port:9003, venueId:000000f427dbb0c9008c00dd000b00379e2, attr:<pyGlobus.io.TCPIOAttr instance at 0x025467B8>, socket:<pyGlobus.io.GSITCPSocket instance at 0x0250BD40>
04/01/03 14:36:40 INFO --------- START TextClient
04/01/03 14:36:40 DEBUG Process network
04/01/03 14:36:40 DEBUG EVENT --- Input
04/01/03 14:36:40 DEBUG <AccessGrid.Events.ConnectEvent instance at 0x0254A388>
04/01/03 14:36:40 DEBUG Get upload url https://vv2.mcs.anl.gov:9005/000000f427dbb0c9008c00dd000b00379e2
04/01/03 14:36:40 DEBUG --after enter venue https://vv2.mcs.anl.gov:9000/Venues/default
04/01/03 14:36:40 DEBUG Set history url: None
04/01/03 14:36:43 INFO Sending data: <AccessGrid.Events.HeartbeatEvent instance at 0x0255ECF0>
04/01/03 14:36:48 INFO Sending data: <AccessGrid.Events.HeartbeatEvent instance at 0x0255ECF0>
04/01/03 14:36:53 INFO Sending data: <AccessGrid.Events.HeartbeatEvent instance at 0x0255ECF0>
04/01/03 14:36:58 INFO Sending data: <AccessGrid.Events.HeartbeatEvent instance at 0x0255ECF0>
04/01/03 14:37:03 INFO Sending data: <AccessGrid.Events.HeartbeatEvent instance at 0x0255ECF0>
04/01/03 14:37:08 INFO Sending data: <AccessGrid.Events.HeartbeatEvent instance at 0x0255ECF0>
04/01/03 14:37:12 INFO Sending data: <AccessGrid.Events.DisconnectEvent instance at 0x02472758>
04/01/03 14:37:12 DEBUG Received eof while reading len
04/01/03 14:37:12 ERROR Server closed connection!
Traceback (most recent call last):
File "C:\Python22\Lib\site-packages\AccessGrid\EventClient.py", line 62, in run
raise Exception("EOF")
Exception: EOF
04/01/03 14:37:14 ERROR AccessGrid.VenueClient::Failed to convert venuestate to object
File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py", line 184, in EnterVenue
venueState.name,
AttributeError: structType instance has no attribute 'name'
04/01/03 14:37:14 ERROR AccessGrid.VenueClient::Exception in EnterVenue
04/01/03 14:37:14 DEBUG Go to new venue
04/01/03 14:37:14 DEBUG Is this a server
04/01/03 14:37:14 DEBUG venue url: https://vv2.mcs.anl.gov:8000/Venues/000000f426f5b102008c00dd000b003750e
04/01/03 14:37:14 DEBUG the handler is valid
04/01/03 14:37:14 DEBUG EVENT- Enter venue with url: https://vv2.mcs.anl.gov:8000/Venues/000000f426f5b102008c00dd000b003750e
04/01/03 14:37:14 DEBUG clean up frame and exit
04/01/03 14:37:14 DEBUG Cleanup frame, save data, and exit venue
04/01/03 14:37:14 ERROR Error while trying to enter venue
None
04/01/03 14:37:14 DEBUG Go back to old venue
04/01/03 14:37:14 DEBUG EVENT- Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
04/01/03 14:38:40 ERROR AccessGrid.VenueClient::Exception in EnterVenue
04/01/03 14:38:40 DEBUG Go to new venue
04/01/03 14:38:40 DEBUG Is this a server
04/01/03 14:38:40 DEBUG venue url: https://vv2.mcs.anl.gov:8000/Venues/000000f426f5b102008c00dd000b003750e
04/01/03 14:38:40 DEBUG the handler is valid
04/01/03 14:38:40 DEBUG EVENT- Enter venue with url: https://vv2.mcs.anl.gov:8000/Venues/000000f426f5b102008c00dd000b003750e
04/01/03 14:38:40 DEBUG clean up frame and exit
04/01/03 14:38:40 DEBUG Cleanup frame, save data, and exit venue
04/01/03 14:38:40 ERROR Error while trying to enter venue
None
04/01/03 14:38:40 DEBUG Go back to old venue
04/01/03 14:46:10 INFO --------- END VenueClient
