CVS stuff for AG
Ivan R. Judson
judson at mcs.anl.gov
Mon Oct 21 13:44:58 CDT 2002
> is it going to stay in a sandbox directory? maybe also
> advertise via a
> cname - ag-cvs.mcs.anl.gov or something.
I don't know what you mean by sandbox, but the plan is to use
pachelbel.mcs.anl.gov and enable anonymous cvs on the AG modules.
> are there notes on local access? can we restrict anonymous
> access from
> certain modules, or are we going to be able to just make it
> all accessible
> (my vote...).
We'll be making it all accessible, but there will be a review process
for code that is being proposed to be committed. We'll have to be
extremely careful about not putting broken stuff in -- this process
allows external developers and internal developers to submit
modifications/additions in a symmetric way, which is good for community
vibe.
> I worry a bit about the ag-src name - that's the source of
> one version of
> ag software, but as we add more it might not make sense
> (hence the name I
> used for the SF module).
I think the module name should be AG, 1.0 should be put in with the 1.0
tag, and when we're ready we'll make a 2.0 branch (then we can do bug
fixes to 1.0 and still move ahead on 2.0).
I think that makes sense, but I was up til 3:30 with Isaiah, you never
know :-)
--Ivan
> --bob
> At 01:16 PM 10/21/2002 -0500, Michael E. Papka wrote:
> >The future distribution of AG software will be via anonymous cvs at
> >ANL, we are moving off the sourceforge site (discussed many times no
> >need to be rediscussed here). Justin and Tom have tested this and we
> >think its ready to go, Ivan will be sending mail to ag-tech
> announcing
> >this, along with directions. Justin and Ivan turn these instructions
> >into a web page that can be put on the AG site.
> >Mike
> >-----Original Message-----
> >From: Justin Binns [mailto:binns at mcs.anl.gov]
> >Sent: Friday, October 18, 2002 4:50 PM
> >To: Michael E. Papka
> >Subject: CVS stuff for AG
> >The CVS_ROOT is:
> >:pserver:anonymous at pachelbel.mcs.anl.gov:/sandbox/cvs
> >The password is blank.
> >The relevant modules are:
> >ag-src - the AG java sources and the helper apps. This is what was
> >'agib-1-glue' in the sourceforge repository.
> >ag-dep - this contains two tarballs that have the linux and windows
> >dependencies for building AG stuff. notably, the
> ag-linux-dep tarball
> >contains an entire tree suitable for building ag-src - with that
> >tarball and the ag-src module, you can build the ag jar file
> and helper
> >apps from scratch. NOTE: this also contains the source
> distribution of
> >the Orbacus stuff, for license compliance (at least on *some* level)
> >ag-vic - the AG 'patched' version of UCL vic - a copy of the
> 'ag-vic'
> >module in the sourceforge CVS repo.
> >One note: the reason the dependencies are dealt with as tarballs is
> >that CVS, for some undetermined reason, was corrupting
> certain of the
> >.jar files when I tried to directly check in the tree. If we can
> >figure out why, then we can probably make it cleaner and
> distribute the
> >dependencies as fully expanded modules instead of tarballs, but this
> >method works whereas the other is currently broken. As these
> >dependencies are not likely to change much, and are
> basically binaries,
> >I didn't think it was a big deal to do it this way.
> >Questions/comments welcome.
> >Justin
