CVS stuff for AG
Michael E. Papka
papka at mcs.anl.gov
Mon Oct 21 13:16:59 CDT 2002
The future distribution of AG software will be via anonymous cvs at ANL,
we are moving off the sourceforge site (discussed many times no need to
be rediscussed here). Justin and Tom have tested this and we think its
ready to go, Ivan will be sending mail to ag-tech announcing this, along
with directions. Justin and Ivan turn these instructions into a web page
that can be put on the AG site.
Mike
-----Original Message-----
Sent: Friday, October 18, 2002 4:50 PM
To: Michael E. Papka
Subject: CVS stuff for AG
The CVS_ROOT is:
:pserver:anonymous at pachelbel.mcs.anl.gov:/sandbox/cvs
The password is blank.
The relevant modules are:
ag-src - the AG java sources and the helper apps. This is what was
'agib-1-glue' in the sourceforge repository.
ag-dep - this contains two tarballs that have the linux and windows
dependencies for building AG stuff. notably, the ag-linux-dep tarball
contains an entire tree suitable for building ag-src - with that tarball
and the ag-src module, you can build the ag jar file and helper apps
from scratch. NOTE: this also contains the source distribution of the
Orbacus stuff, for license compliance (at least on *some* level)
ag-vic - the AG 'patched' version of UCL vic - a copy of the 'ag-vic'
module in the sourceforge CVS repo.
One note: the reason the dependencies are dealt with as tarballs is that
CVS, for some undetermined reason, was corrupting certain of the .jar
files when I tried to directly check in the tree. If we can figure out
why, then we can probably make it cleaner and distribute the
dependencies as fully expanded modules instead of tarballs, but this
method works whereas the other is currently broken. As these
dependencies are not likely to change much, and are basically binaries,
I didn't think it was a big deal to do it this way.
Questions/comments welcome.
Justin
