FW: [AG-TECH] Multiple Capture Challenge
Ivan R. Judson
judson at mcs.anl.gov
Sun Nov 10 21:52:11 CST 2002
Ivan R. Judson .~. http://www.mcs.anl.gov/~judson
Futures Laboratory .~. 630 252 0920
Argonne National Laboratory .~. 630 252 6424 Fax
> -----Original Message-----
> From: owner-openmash-developers at bmrc.berkeley.edu
> [mailto:owner-openmash-developers at bmrc.berkeley.edu] On
> Behalf Of Matthew Delco
> Sent: Sunday, November 10, 2002 9:39 PM
> To: 'Open Mash Developers'
> Subject: RE: [AG-TECH] Multiple Capture Challenge
> static VfwScanner find_vfw_devices(4);
> is a piece of code that's basically used in all mash video
> device "drivers". It looks like a function definition/call,
> but what it's really doing is allocating an instance of
> "VfwScanner" called "find_vfw_devices", passing the argument
> (4) to the constructor.
> So, you want to examine VfwScanner::VfwScanner() in
> video-win32.cc, which basically dynamically allocates an
> instance of "VfwDevice" for each device that's returned by
> V4L's capGetDriverDescription().
> Thus, increasing 4 to a larger value seems appropriate. In
> fact, it might be better to avoid a static value, and use
> something like the following for
> VfwScanner::VfwScanner():
> char deviceName[80] ;
> char deviceVersion[100] ;
> int index = 0;
> while(capGetDriverDescription(index++,
> (LPSTR)deviceName,
> sizeof(deviceName),
> (LPSTR)deviceVersion,
> sizeof(deviceVersion))) {
> char* wrk = new char[32];
> sprintf(wrk, "VideoCapture/VFW%d", index-1);
> new VfwDevice(wrk, strdup(deviceName), index-1);
> MD
> P.S. I only sent this to openmash-developers and not Andrew
> Heisen since pop/imap (at least as I have it configured) is
> restricted to local e-mail accts.
> > I just looked at the source code for vic. There is a static array
> > inside the video device abstractions that only allows 4 devices. It
> > looks like it would be very easy to change it.
> > If you download the current Open Mash code and go to the file
> > mash-code/mash/video/video-win32.cc
> > Then search for a line with
> > I am not certain that this is the place that upper bound on
> devices is
> > set, but it might be. I tried to find the definition of the
> > find_vfw_devices but couldn't find it. It is part of the
> MS software
> > libraries. I'm pretty sure the arguement is the number of devices.
> so,
> > try changing that to 6 or 8 and recompiling the code - that
> might fix
> > your problem.
> > Larry
