FW: DPPT is now in cvs?
Robert Olson
olson at mcs.anl.gov
Sat Nov 9 13:27:49 CST 2002
there was already a readme with instructions on how to build and where to
find the tools.
At 01:18 PM 11/9/2002 -0600, Ivan R. Judson wrote:
>Perhaps even a simple readme would suffice to collect pointers to tools,
>thoughts (even fragments of them) and some of what you mean (more
>completely) below?
>--Ivan
>Ivan R. Judson .~. http://www.mcs.anl.gov/~judson
>Futures Laboratory .~. 630 252 0920
>Argonne National Laboratory .~. 630 252 6424 Fax
> > -----Original Message-----
> > From: Bob Olson [mailto:olson at mcs.anl.gov]
> > Sent: Friday, November 08, 2002 6:51 AM
> > To: Ivan R. Judson
> > Cc: ag-dev at mcs.anl.gov
> > Subject: Re: FW: DPPT is now in cvs?
> > I'll answer questions about it; at this point putting
> > together a guide like that isn't a priority (that dppt would
> > not be a good starting point for new code, esp for linux, for
> > a number of reasons) until after the SC panic is done, imho.
> > --bob
> > On Fri, 8 Nov 2002, Ivan R. Judson wrote:
> > > Bob,
> > > Can you write up some notes so external developers can work on the
> > > dppt stuff? In particular note Chris' comment below. He's
> > working on
> > > getting a dppt like solution working on their all linux
> > installations.
> > > Thanks,
> > > --Ivan
> > > > From: Christoph Willing [mailto:chris at vislab.usyd.edu.au]
> > > > Sent: Wednesday, November 06, 2002 3:32 PM
> > > > To: Ivan R. Judson
> > > > Subject: RE: DPPT is now in cvs?
> > > > Thanks Ivan,
> > > > I've downloaded it and had a browse around the code. The
> > > > biggest issue preventing a really quick solution looks like
> > > > it might be the contents of a directory named "activex". It
> > > > seems to be generated from some tool out of the Windows java
> > > > sdk - I'm not sure if that matters once the java has been
> > > > generated. I'll let you know as soon as (if?) I have any
> > > > success with it.
> > > > chris
> > > > On Wed, 2002-11-06 at 23:38, Ivan R. Judson wrote:
> > > > > Didja find it? Module dppt in the cvs repository.
> > > > > --Ivan
> > > > > > Sent: Wednesday, October 30, 2002 9:22 PM
> > > > > > To: Ivan R. Judson
> > > > > > Subject: DPPT not in cvs?
> > > > > > Hi Ivan,
> > > > > > The system support people fixed the anonymous cvs
> > problem I was
> > > > > > having the other day. Since checking out the AG
> > module (in fact
> > > > > > all the modules you announced by email a while back)
> > I haven't
> > > > > > been able to find any distributed ppt source code.
> > > > > > Is the java source code for dppt available? I'd like to do a
> > > > > > version that runs on linux & uses Crossover Office or WINE to
> > > > > > run the powerpoint application.
> > > > > > Thanks,
> > > > > > chris
> > > > > > Chris Willing Telephone (61-2)
> > 9351 3005
> > > > > > VisLab, A28 Facsimile (61-2)
> > 9351 1880
> > > > > > University of Sydney
> > > > > > NSW 2006 Australia
> > http://www.vislab.usyd.edu.au
> > Chris Willing Telephone (61-2) 9351 3005
> > > > VisLab, A28 Facsimile (61-2) 9351 1880
> > > > NSW 2006 Australia http://www.vislab.usyd.edu.au
