Services stuff
Robert Olson
olson at mcs.anl.gov
Tue Dec 10 12:39:57 CST 2002
Implementation of the services code are available in CVS on green unix in
/home/FuturesLab/Software/CVSMaster, module VV2 in the service_core directory.
The agsd tool is installed on moonbeam; to use do this:
setenv AGVV_LOCATION /usr/local/vv2
source /usr/local/vv2/etc/agvv-user-env.csh
or if your login shell is bash
exportAGVV_LOCATION=/usr/local/vv2
./usr/local/vv2/etc/agvv-user-env.sh
then you should be able to run the agsd command as in the slides. (attached).
--bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20021210/126cab9d/attachment.htm>
Name: Services in pyGlobus and the AG.ppt
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20021210/126cab9d/attachment.obj>
