Ag2
Robert Olson
olson at mcs.anl.gov
Wed Dec 4 11:19:45 CST 2002
Attached please find the beginnings of a programmer's guide (with some
library reference information) to the current venues software.
I am curious if there is a concrete target (defining exactly what
functionality is required)for the AG2 release in 3 weeks, and what features
it will include. I offer the following features of the existing code, for
consideration in your decision to start from scratch:
Services layer, separate from the core Venue code. Intended use
is to provide a protocol-neutral interface between the underlying
service implementation and the application code, such that
applications can swap between protocols without change.
XMLRPC service implementation that fully supports Globus
authentication and authorization mechanisms.
Implementation of a Venue service complying with the interface
spec as I included in the venues design document. This service
uses the ZODB Python object database for its backing store.
Integration of a venues-based service registry for the addition
of dynamic services to a venue.
Implementation of a Venue client also complying with the
interface spec. This client supports navigation and integration
with workspace docking.
Workspace docking clients include a shared web browser, GASS-
based file transfer, service-based distributed powerpoint. It
also integrates the external tools VNC, wbd (UCL whiteboard),
nte (UCL shared text editor), LBNL intergroup chat. There
is also a shared file service that requires some more work.
Windows installer packages for the dependent tools, Globus library,
and the venues client itself.
Tested (and developed) on both Windows and Linux).
I was intending on spending the next couple weeks nailing some of the
glitches we discovered in running this code at SC, and in completing enough
documentation for people to both use the software and to build new services
and tools to integrate with it.
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20021204/6d3db2ea/attachment.pdf>
