Fwd: [NMI] globus development using NMI release? (fwd)
Bob Olson
olson at mcs.anl.gov
Thu Aug 8 14:56:01 CDT 2002
FYI.
---------- Forwarded message ----------
Date: Thu, 08 Aug 2002 14:53:32 -0600
To: olson at mcs.anl.gov
Subject: Fwd: [NMI] globus development using NMI release?
(NCSA Ticket System users can access the ticket through the following url:
https://irg-internal.ncsa.uiuc.edu/tickets/index.cgi?ticket=050899)
(Concerning Ticket No. 050899)
Bob,
Here is the response from NMI Globus Support.
-Praveen
Praveen Kumar J
NMI Support Services
nmi-support at nsf-middleware.org
http://www.nsf-middleware.org
> For NMI R1 we didn't include dev packages (which allow someone to
> build software against the globus libraries) because of issues with
> globus_core. But the dev packages _will_ be in R2 and beyond as we are
> moving globus_core into GPT.
> > FROM: Praveen Jagadishprasad
> > Hi,
> > Could you please help this user.
> > Thanks,
> > Praveen
> > Praveen Kumar J
> > mailto : olson at mcs.anl.gov
> > > Hi --
> > > I just installed the NMI globus client release, and am trying to
> > > build an application. However, globus-makefile-header tells me it
> > > can't find the packages it's looking for:
> > > [olson at localhost security]$ /usr/grid/sbin/globus-makefile-header -flavor=gcc32dbg -link=shared
> > > globus_io globus_gss_assist
> > > No packages were found that matched your query!
> > > I also don't see a /usr/grid/include. Should I be able to compile
> > > code using the NMI globus release?
> > > BTW, are there archives of the NMI mailing lists available?
> > > thanks,
> > > --bob
> Scott Gose
> gose at mcs.anl.gov
