r6773 - trunk/packaging
ag-cvs.mcs.anl.gov at ci.uchicago.edu
Fri Apr 9 16:10:55 CDT 2010
Author: turam
Date: 2010-04-09 16:10:54 -0500 (Fri, 09 Apr 2010)
New Revision: 6773
Modified:
trunk/packaging/BuildSnapshot.py
Log:
update svn url
Modified: trunk/packaging/BuildSnapshot.py
--- trunk/packaging/BuildSnapshot.py 2010-04-09 13:34:29 UTC (rev 6772)
+++ trunk/packaging/BuildSnapshot.py 2010-04-09 21:10:54 UTC (rev 6773)
@@ -155,7 +155,7 @@
if not options.nocheckout:
# Either we check out a copy
- svnroot = "https://www.ci.uchicago.edu/svn/accessgrid/trunk"
+ svnroot = "https://svn.ci.uchicago.edu/svn/accessgrid/trunk"
if not options.tag:
tagString = ""
@@ -169,7 +169,10 @@
if options.verbose:
print "BUILD: Checking out code with command: ", checkout_cmd
- os.system(checkout_cmd)
+ ret = os.system(checkout_cmd)
+ if ret:
+ print '%s failed with %d; exiting' % (checkout_cmd,ret)
+ sys.exit(1)
# Get the version via popen
More information about the ag-cvs
