AGTk 2.0 Beta 1 Released! (Correction)
Ivan R. Judson
judson at mcs.anl.gov
Sat Mar 15 15:44:40 CST 2003
The Access Grid Toolkit v.2.0 Beta 1 is available for download.
The correct URL is:
http://www.mcs.anl.gov/fl/research/accessgrid/software/2.0-beta1/index.html
Please download and try the beta software. Feedback can be provided either
through bugzilla and/or the ag-tech mailing list. Please provide feedback,
pointers to information, or other pertinent information for us to
incorporate into Beta 2.
The AG Team
Release Notes for AGTk 2.0 Beta 1
Installation
73 - Windows globus proxy cert config confusing
74 - Windows confusing end of installation
124 - Windows Weird tracebacks
131 - Linux RPM dependency problems
148 - Linux Globus install fails to correctly install trust
certificates
157 - Windows Could not find path to Vic/Rat
159 - Windows AG client doesn't accept certificate information
Media Tools
65 - Linux rat not starting on entering a venue
66 - Linux vic and QuickCam not happy
Node Management
53 - All Services don't update automatically
79 - Windows NodeService picks up wireless but not wired network conne...
129 - Windows Renegade processes
133 - Linux Node mgmt problems on Linux
138 - Windows Add Service confusing
Virtual Venue Server
77 - Windows Venue Server caused VenueClient and Nodemanager to hang
98 - Windows workaround required to get data services working
101 - Linux HaveValidCertificate() method request
144 - Linux Exceptions
150 - Linux type request
163 - Linux enue.GetEncryptMedia()
Virtual Venue Client
152 - Linux child process is not killed by SIGINT
160 - Windows Data Store output to log
161 - Linux duplication
164 - Linux data store problems
*Resolved Bugs Since 2.0 alpha 4*
25 - Obtaining Globus Certificate Instructions Wrong
49 - AGNodeManagement can't find services
58 - SetupVideo.py config location
80 - client crash
85 - Node Manager UI starts minimized
86 - no error message produced if grid cert proxy is expired
87 - rat unmutes microphone in playback settings
88 - Need option for using encryption in venues
93 - Can't add services...
95 - default config tries adding services to munich.mcs.anl.gov
97 - periodic errors in checkpointing
103 - winglobus.exe
106 - Feature Request
107 - mcast-support description is confusing
109 - Pathname problem on 'Download certificates from Unix System'
110 - VenueServer leaves python processes when shutting down
111 - Node Service dies on launch
112 - Similar functionality needed for My Venues as My Favorites
113 - weird link to activestate python
115 - Discrepancy between webpage and installer
119 - Client UI won't start
121 - venue server crash on client enter
122 - 2.0-alpha4 needs to be added to Bugzilla versions list
123 - traceback on startup of node mgmt
125 - Bad execution order assumption in RunMe
126 - Software Web Page Alpha4 link points to Alpha2
137 - Viewing profiles comments
139 - venue names not sorted
140 - Can't add a venue
141 - Globus Configuration
143 - Can't modify a venue
146 - Distinguished Name
147 - Error starting VenueServer.py
149 - not authorized
151 - add service failed:
153 - remove data from venue
154 - venue encryption
155 - venue.RemoveStream(stream)
158 - should enforce creating user profile
More information about the ag-announce
