AGTk 2.0 alpha 4 is Available
Ivan R. Judson
judson at mcs.anl.gov
Sat Mar 1 18:51:00 CST 2003
The Access Grid Toolkit v.2.0-alpha-4 is available for download.
http://www.mcs.anl.gov/fl/research/accessgrid/software/2.0-alpha4/index.html
Release Notes
Known Issues:
General
- There is a known issue that affects hosts with multiple interfaces running
windows. This is currently under investigation, but there is no work around
yet. (Bugs: 79, 73)
- There is some confusion with certificates. Which is being addressed with
clearer instructions and user interface improvements.
Node Management
- The services list may not update after adding a service.(Bug 53)
Workaround: Click on View/Update and then on then rechoosing the host
refreshes this list
- No services are found. (linux only) (Bug 49)
Workaround: Start AGNodeService.py from /usr/share/AccessGrid
- VideoProducerService fails to find a configured device. (linux only) (Bug
58)
Workaround: Run SetupVideo.py from /usr/share/AccessGrid and start
AGServiceManager.py from /usr/share/AccessGrid.
- Loading a config fails with "No such file or directory". (linux only) (Bug
54)
Reporting Bugs:
To report any bugs or feature requests, please use our bugzilla server at
http://bugzilla.mcs.anl.gov/accessgrid
Getting the Software:
To download the software go to
http://www.mcs.anl.gov/fl/research/accessgrid/software and follow the
instructions there.
The AGTk Team
More information about the ag-announce
