[Ad-dev] [openAD] #288: independent/dependent declaration of common block variables without actual reference in the same compile unit fails
OpenAD trac at mcs.anl.gov
Fri Feb 22 09:13:49 CST 2013
 Reporter:  utke          |       Owner:  utke
     Type:  defect        |      Status:  new
 Priority:  major         |   Milestone:
Component:  OpenADFortTk  |    Keywords:
 the compile unit that declares independent/dependent common block
 variables as pragma but have no actual reference in it fail the activity
 analysis because there is no location from which to establish a
 dependency.
 see
 Regression/testRoundTrip/examples/globalActive_cbNoRef
Ticket URL: <https://trac.mcs.anl.gov/projects/openAD/ticket/288>
OpenAD <http://www.mcs.anl.gov/openad>
Bug tracking for OpenAD components
More information about the Ad-dev mailing list
