[Ad-dev] Managed to build
Sri Hari Krishna Narayanan snarayan at mcs.anl.gov
Wed May 23 06:43:42 CDT 2012
Kaveh,
The latest revision has been developed with a lot more features that
are used
to support  Fortran Input that may not work for the C side right now.
Can you please try revision 631 or 587
with boost_1_43_0. I can provide better guidance for this. You should
be able to upgrade to the latest version in a couple of weeks.
Krishna
On May 23, 2012, at 6:23 AM, Kaveh Vahedipour wrote:
> I had to take the newest. 631 had another problem. Which I know how
> to fix in tehory but didn't wanna find out how complicated it would
> be in the end. Something about the compiler not knowing how to make
> a boost::unorder_list or so to ...
> But I might know where the problem was anyways. It turns out that
> angel just built the static library and make was happy if an error
> had occured down the road and you thought that you had fixed it.
> I have
> 64bit precise pangelot
> gcc-4.4
> rose-0.9.5a-18998
> xerces-2.8.0
> xaifBooster (rev 125)
> angel (rev 82)
> boost 1.46.1
> openanalysis 1.0 (svn)
> Cheers,
> Kaveh.
> On 23 May 2012, at 12:46, Sri Hari Krishna Narayanan wrote:
>> Hi Kaveh,
>> Can you tell me which revision of ADIC you checked out?
>> Thanks,
>> Krishna
>> On May 23, 2012, at 4:15 AM, Kaveh Vahedipour wrote:
>>> Dear ADIC team,
>>> I have done my best to get ADIC2 compiled. I have finally made it.
>>> After many hours of trouble shooting code & build files. This is
>>> on 64bit Linux, btw.
>>> However, this is the error that I am faced with now:
>>> <snip>
>>> kvahed at beo-38 ~/ADIC/adic_source/tests/basic/exec/
>>> mini1_forward_array> make
>>> make: Warning: File `Makefile' has modification time 97 s in the
>>> future
>>> ==== Using ADIC to generate derivative code (forward-dense)
>>> ======mini1_dense_forward.ad.c===
>>> /usr/local/bin/adic2 mini1.c -mforward --nary
>>> ADIC DEBUG[Command Line][0]: ../adic_source/util/
>>> BoostCommandLine.cpp 271 ROSE command line arguments: -rose:c
>>> mini1.c
>>> ERROR: caught exception: (../adic_source/main/ADIC.cpp:
>>> 322)LogicException: preprocessTemplateFile: no template file
>>> named  found
>>> make: *** [mini1_dense_forward.ad.c] Error 255
>>> </snip>
>>> Do you have any suggestions as to how to proceed from here?
>>> With highest regards,
>>> Kaveh Vahedipour.
>>> Kaveh Vahedipour
>>> Institute of Neuroscience and Medicine
>>> Medical Imaging Physics
>>> Forschungszentrum Juelich GmbH
>>> 52425 Juelich
>>> Germany
>>> Phone:  +49-2461-611921
>>> Fax:    +49-2461-611919
>>> E-mail: k.vahedipour at fz-juelich.de
>>> Web:    http://www.fz-juelich.de/inm/inm-4
>>> 52425 Juelich
>>> Sitz der Gesellschaft: Juelich
>>> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
>>> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
>>> Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
>>> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
>>> Prof. Dr. Sebastian M. Schmidt
>>> Kennen Sie schon unseren neuen Film? http://www.fz-juelich.de/film
>>> Kennen Sie schon unsere app? http://www.fz-juelich.de/app
> Kaveh Vahedipour
> 52425 Juelich
> Germany
More information about the Ad-dev mailing list
