[Ad-dev] [ADIC] #48: Enhancements for the Runtime Library
ADIC
trac at mcs.anl.gov
Wed Jan 19 11:37:14 CST 2011
Reporter: snarayan | Owner: snarayan
Type: enhancement | Status: new
Priority: major | Milestone:
Component: Canonicalization | Version:
Keywords: |
1. Separate the Sparse and Dense runtime libraries from the main ADIC
library.The user should also get a local copy of the runtime library which
should also solve the issue of setting the ADIC_GRADVEC_LENGTH in two
places.
2. Make the sparse and dense runtime interfaces the same. Therefore, the
differentiated code will be created once, but can be linked against the
sparse or dense libraries on demand.
3. All routines in the runtime libraries should be changed to macos as far
as possible.
4. Dynamically create both the sparse and dense Sax/Saxpy macros.
5. Instead of an STL::set and and STL:: list of sets to maintain non-zero
Jacobian, think of other ways.
6. All DERIV_TYPE objects should have their grad array zeroed out,
temporaries should have their values zeroed out. This step maybe unneeded
if XAIFBooster always sets the values of temporaries before use.
7. Create a way for the user to know that the generated code can overrun
stack space, and that temporaries and existing variables should be
dynamically allocated.
8. Create a way to dynamically allocate temporaries and existing
variables.
Ticket URL: <http://trac.mcs.anl.gov/projects/ADIC/ticket/48>
ADIC <http://trac.mcs.anl.gov/projects/ADIC>
ADIC: Automatic Differentiation for C and C++
More information about the Ad-dev
