[Ad-dev] [openAD] #111: posprocessor ( and transformFile): initialization in activated type for DATA
OpenAD
trac at mcs.anl.gov
Wed Apr 27 14:29:24 CDT 2011
DATA
Reporter: Utke | Owner: hlcm
Type: defect | Status: assigned
Priority: 3 | Milestone:
Component: SourceProcessing | Keywords:
Comment(by hlcm):
The following is acceptable syntax & compiles successfully with nagfor:
module m
public :: mType
type mType
integer:: c1
integer:: c2=0
end type
end module
program p
use m
type(mType) :: x=mType(2,1)
type(mType) :: v
data v%c1/2/
print*, x,v
end program
Therefore it would be possible to explicitly initialize only the value
component of the active type and leave the default-initialized derivative
component alone.
For a more complicated case, it would be possible to make a transformation
for a structure s with components a, b & c where b becomes active in the
following manner
data s / 1,2,3 /
data s%a, s%b%v, s%c / 1,2,3 /
However it may not be worth the effort until a problem arises
Ticket URL: <https://trac.mcs.anl.gov/projects/openAD/ticket/111#comment:5>
OpenAD <http://www.mcs.anl.gov/openad>
Bug tracking for OpenAD components
More information about the Ad-dev
