[Ad-dev] [openAD] #224: open64 does not distinguish 1st and 2nd nesting level of SRs
OpenAD
trac at mcs.anl.gov
Tue Sep 28 11:09:18 CDT 2010
Reporter: utke | Owner: utke
Type: defect | Status: accepted
Priority: major | Milestone: scale1
Component: Open64 front end | Keywords:
Changes (by utke):
* milestone: => scale1
Comment:
Replying to [comment:4 utke]:
> The following test case illustrate the symptoms further:
> OpenADFortTk/Regression/TestSources/sideEffectNested2.f90
> (the deepest level routine is elevated but that makes the used variable
out-of scope -> compiler error)
> xand
> OpenADFortTk/Regression/TestSources/sideEffectNested4.f90
> The example compiles and produces the correct output but the XAIF
representation is incorrect in the side effiect lists of foo2
This last part is fixed by
http://mercurial.mcs.anl.gov/ad/OpenADFortTk/rev/f4acb6925a14
> <xaif:SideEffectReference vertex_id="1">
> <xaif:SymbolReference vertex_id="1" scope_id="5"
symbol_id="L_X_1"/>
> </xaif:SideEffectReference>
> Where the scope_id=5 is clearly wrong
Ticket URL: <https://trac.mcs.anl.gov/projects/openAD/ticket/224#comment:5>
OpenAD <http://www.mcs.anl.gov/openad>
Bug tracking for OpenAD components
More information about the Ad-dev
