[Ad-dev] [openAD] #209: assumed-size arrays
OpenAD
trac at mcs.anl.gov
Tue Mar 30 23:40:18 CDT 2010
Reporter: utke | Owner: utke
Type: task | Status: new
Priority: minor | Milestone:
Component: multiple components | Keywords:
An assumed-size array (F77 idiom) is a dummy argument that has a '*' in
the dimension specification. The dummy argument will assume the size (but
not necessarily the shape or extent) of the actual argument. No
lbound/ubound/size info can be extracted from the assumed-size array
dimension. Consequently it is impossible to create any temporaries for
such arrays.
HOWEVER, for many practical uses the actual size of the array will still
be known at call time, because it is passed in another dummy argument.
In that case the suggested workaround is
to replace the "*" in the dimension with the dummy argument that
contains the size (or a permitted expression thereof)
The alternative in current Fortran are assumed-shape arrays.
They do require an interface and consequently matching shape.
Ticket URL: <http://trac.mcs.anl.gov/projects/openAD/ticket/209>
OpenAD <http://www.mcs.anl.gov/openad>
Bug tracking for OpenAD components
More information about the Ad-dev
