[Ad-dev] [openAD] #191: activiy analyisis does not activate certain module variables
OpenAD
trac at mcs.anl.gov
Mon Jan 25 17:39:13 CST 2010
Reporter: utke | Owner: utke
Type: defect | Status: accepted
Priority: major | Milestone: MATWS adjoint
Component: OpenAnalyis (old branch) | Keywords:
Comment(by utke):
The problem is rooted in the issue that the OA interface produces fully
qualified names only for
Common block variables. There was the assumption that all uses of module
variables are referring to the same entry in the global symbol table. That
is however only true for all uses external to the module while use
internal to the module refer to a different variable. Therefore it still
makes sense to use the fully qualified name mechanism for module variables
and the logic is being
reintroduced to the OA interface.
Ticket URL: <https://trac.mcs.anl.gov/projects/openAD/ticket/191#comment:4>
OpenAD <http://www.mcs.anl.gov/openad>
Bug tracking for OpenAD components
More information about the Ad-dev
