[Ad-dev] [ADIC] #38: Configuration options
ADIC trac at mcs.anl.gov
Fri Feb 5 11:26:25 CST 2010
 Reporter:  anonymous            |       Owner:  snarayan
     Type:  enhancement          |      Status:  new
 Priority:  major                |   Milestone:  UseOA-ROSE integration
Component:  Configuration/Build  |     Version:
 Keywords:                       |
 If the configuration options for ADIC specifying the prefix of  XB has a
 '/' at the end,
 then the resultant path has a '//' in the adic2.init file. This creates
 failure for reasons unknown. The ADIC error message is :
 ADIC ERROR[OA2XAIF]: DefaultEdge::DefaultEdge: NULL source vertex.
 Exiting...
 This error was seen when symbolic links were used in the configuration
 options as well.
 So a fix maybe to simply resolve all paths fully before they are entered
 into the adic2.init file.
Ticket URL: <http://trac.mcs.anl.gov/projects/ADIC/ticket/38>
ADIC <http://trac.mcs.anl.gov/projects/ADIC>
ADIC: Automatic Differentiation for C and C++
More information about the Ad-dev mailing list
