[Swift-devel] commits
Mihael Hategan hategan at mcs.anl.gov
Fri Apr 17 19:25:08 CDT 2015
I committed the following:
1. standard library stuff. There are some tests for it too. You can use
it by saying
import "stdlib.v2";
(the exact form of the string "stdlib.v2" is open to discussion).
2. Function/procedure overloading.
3. Structure/sparse array initializers. You can now say mystruct v = {a:
1, b: 3.4}, etc. For sparse arrays, you can say int[] a = {0: 1, 100: 2,
1000: 3} or int[string] b = {"a": 1, "b": 2, ...}.
4. The documentation formatting updates. Since I last mentioned this, I
made a small change that makes the header look more like the swift site
header (except smaller in size).
Mihael
