[Swift-devel] Multiple output files
Michael Wilde wilde at anl.gov
Sat Mar 22 11:31:52 CDT 2014
This is now filed as enhancement bug 1225 and assigned to you, Mihael.
The description has been revised as you suggested, to propose that the
feature be first done using simple_mapper rather than a new mapper.
- Mike
On 3/21/14, 8:39 AM, Michael Wilde wrote:
> Mihael, All,
> I'd like to propose a Swift/K feature to provide a reasonable solution
> to this very common need for an app to return a dynamically determined
> set of files.
> file dynarry[ ] <runtime; prefix="myoutput.", suffix=".out",
> indexes="int">;
> dynarry = myApp(myArgs);
> The "runtime" mapper should initially have the same arguments and
> semantics (roughly) as simple_mapper, except for two new arguments:
>  "indexes" which determines how the matched file names will be indexed
> in the returned array
> "int" | "string" | "sequential"
> sequential: return the matched files as consecutive integer indices
> starting with 0
> int: expect the filename component between prefix and suffix to be
> convertible to an integer, and use that as the index
> eg myfile.012.out and myfile.204.out will return an array with the
> mapped files at indices 12 and 204.
> string: similar to int but return a string-indexed associative array.
> "sequential" is simplest and should be the default.
> "paths" which determines if the match names will be absolute or
> relative to the job dir
> paths="relative" | "absolute"
> (may not be needed if this can be determined uniquely based on the
> location argument.
> swiftwrap will allow array variables mapped in this manner to have any
> number of files, including zero. I.e. "runtime-mapped" files should
> not be listed in the expected output list for an app invocation. Its
> up to the users app to ensure that some files match the pattern. An
> additional arg could set e.g. minfiles and/or maxfiles, in which case
> the wrapper code needs to validate the count of files matched and
> returned, but not their exact names.
> We can call this mapper "experimental" until we validate its usability
> and suitability as a permanent feature. But as we hope to revise the
> entire mapper family and semantics, in a sense all mappers are subject
> to change.
> Mihael, is the definition sound, and how long would it take you to
> develop it?
> Thanks,
> - Mike
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140322/bfc81f83/attachment.html>
