[Swift-devel] Re: Getting VMs from FG for use with swift
Michael Wilde wilde at mcs.anl.gov
Wed Jun 8 09:51:36 CDT 2011
Hi John, David,
A meeting sounds good. When are you in town?  Or we can meet by phone tomorrow or Friday.
Re Demos, we can pick from these to start:
- a simple BLAST or "mock BLAST" demo: split a file, blast each segment against a DB,
- protein-RNA docking with "modFTDock" (simple script, real science)
- MODIS: analyze land use satellite data (has graphics)
Mike
----- Original Message -----
> That sounds great. Perhaps we should have another meeting to discuss
> what we can demo from here.
> On 06/08/2011 02:38 AM, David Kelly wrote:
> > It's not called directly from Swift, but the start-coaster-service
> > script does that. It calls
> > bootit.sh(cloudinitd), extracts information from the JSON output,
> > sets up reverse SSH tunneling if
> > needed, starts the worker perl script on each node, and then
> > generates Swift configuration files
> > with the correct values.
> > David
> > On Tue, Jun 7, 2011 at 11:27 PM, John Bresnahan
> > <bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>>
> > wrote:
> >     Are we at a point where we can have cloudinit.d called from
> >     swift and have the hostnames parsed
> >     from the json output file? That might make a good demo.
> >     On 06/07/2011 03:01 PM, David Kelly wrote:
> >         Yep, I am using the VMs I get from cloudinitd with Swift.
> >         The only problem I sometimes notice is
> >         that cloudinitd can be pretty slow to finish.. somewhere
> >         between the point where it prints the
> >         information about the hosts (hostname, instance id, etc) but
> >         before it prints the success
> >         message
> >         and exits. I was thinking maybe it's related to the hotel
> >         filesystem problems from last
> >         week, but
> >         I'm not sure. Other times cloudinitd finishes quickly
> >         without any major delays.
> >         Once it gets past initializing the VMs it runs great. I've
> >         been testing with a script called
> >         hostsn.swift which basically just calls 'hostname' several
> >         times and sends the output to a file.
> >         It's useful for verifying that all the VMs are processing
> >         work. When you get a chance to test it
> >         out, the hostsn script is in the swift examples directory.
> >         You can call it with something
> >         like this:
> >         swift -sites.file sites.xml -tc.file tc.data -config cf
> >         hostsn.swift -n=100
> >         N is the number of 'hostname' processes to launch.. the
> >         files will be created in a directory
> >         called
> >         outdir.
> >         Feel free to send me an email when you get a chance to look
> >         at it and we can talk more about it.
> >         David
> >         On Tue, Jun 7, 2011 at 6:59 PM, John Bresnahan
> >         <mailto:bresnaha at mcs.anl.gov> <mailto:bresnaha at mcs.anl.gov
> >         <mailto:bresnaha at mcs.anl.gov>>>
> >         wrote:
> >             great! I will take a look at that when I can (I am on
> >             travel right now).
> >             Getting back to using cloudinit.d for swift... we you
> >             able to use the VMs you got from
> >             FutureGrid with swift? I was hoping we could start
> >             encorperating that into swift, or at
> >         least
> >             acquire a set of VMs and use those as you currently use
> >             static machines in some demos.
> >             From: "David Kelly" <davidkelly999 at gmail.com
> >             <mailto:davidkelly999 at gmail.com>
> >         <mailto:davidkelly999 at gmail.com>>>
> >             To: "John Bresnahan" <bresnaha at mcs.anl.gov
> >         <mailto:bresnaha at mcs.anl.gov <mailto:bresnaha at mcs.anl.gov>>>
> >             Cc: "Mike Wilde" <wilde at mcs.anl.gov
> >             <mailto:wilde at mcs.anl.gov> <mailto:wilde at mcs.anl.gov
> >         <mailto:wilde at mcs.anl.gov>>>, "swift-devel"
> >         <swift-devel at ci.uchicago.edu
> >         <mailto:swift-devel at ci.uchicago.edu>
> >         <mailto:swift-devel at ci.uchicago.edu>>>
> >             Sent: Tuesday, June 7, 2011 2:39:20 PM
> >             Subject: Re: Getting VMs from FG for use with swift
> >             Hello John,
> >             I have attached a quickstart guide I wrote on how to get
> >             Swift working with futuregrid
> >         by using
> >             the new Swift coaster service scripts. This will require
> >             the latest development version of
> >             Swift. Instructions on how to download/install are in
> >             the document.
> >             Please let me know if you have any questions, if
> >             anything is unclear, or if you run into any
> >             problems. Thank you!
> >             Regards,
> >             David
> >             On Tue, May 24, 2011 at 3:18 PM, John Bresnahan <
> >         > wrote:
> >             The GPFS server on the FG cluster hotel died yesterday
> >             so I cannot get you your credentials.
> >               I'll get back to you when it is up again. Once it is
> >               back the process for getting the
> >         needed
> >             access keys is described here:
> >         https://portal.futuregrid.org/tutorials/nimbus
> >             On 05/23/2011 05:24 AM, David Kelly wrote:
> >             Hi John,
> >             I now have a futuregrid account and am added to a
> >             project. I am now trying to get our
> >         scripts
> >             working together.
> >             I ran into a few problems at first when trying to run
> >             the futuregrid scripts. On the
> >         first system I
> >             tried I was getting a traceback. It is possible that the
> >             system I was using has older
> >         versions of
> >             some of the needed libraries. Then I tried it on a more
> >             system that is more frequently
> >         updated - my
> >             laptop running Ubuntu 10.10. It needed a newer version
> >             of the Python crypto tools
> >         installed, so I
> >             installed that (and the python development libraries)
> >             and that part seems fine now.
> >             I am now up to the point of the install script where it
> >             is trying to register keys, but
> >         it is
> >             failing. My guess is that I need to change
> >             FUTUREGRID_IAAS_ACCESS_KEY and
> >         FUTUREGRID_IAAS_SECRET_KEY
> >             in env.sh. I'm not sure what these should be exactly.
> >             Are these the contents of my ssh
> >         keys, an ssh
> >             key and a passphrase, or some other type of security?
> >             I've tried a few combinations of
> >         different
> >             things but haven't had much luck yet.
> >             Thanks!
> >             Regards,
> >             David
> >             Traceback from earlier:
> >             Installing setuptools.......................done.
> >                Complete output from command
> >                /autonfs/home/davidk/swift-vm-...ython
> >             /autonfs/home/davidk/swift-vm-...stall pip:
> >                Searching for pip
> >             Reading http://pypi.python.org/simple/pip/
> >             Reading http://pip.openplans.org
> >             Reading http://www.pip-installer.org
> >             Best match: pip 1.0.1
> >             Downloading
> >         http://pypi.python.org/packages/source/p/pip/pip-1.0.1.tar.gz#md5=28dcc70225e5bf925532abc5b087a94b
> >             Processing pip-1.0.1.tar.gz
> >             Running pip-1.0.1/setup.py -q bdist_egg --dist-dir
> >             /tmp/easy_install-GHsjHX/pip-1.0.1/egg-dist-tmp-rXjQ7L
> >             Traceback (most recent call last):
> >                File
> >                "/autonfs/home/davidk/swift-vm-boot/ve/bin/easy_install",
> >                line 8, in <module>
> >                  load_entry_point('setuptools==0.6c11',
> >                  'console_scripts', 'easy_install')()
> >                File
> >         "/autonfs/home/davidk/swift-vm-boot/ve/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg/setuptools/command/easy_install.py",
> >             line 1712, in main
> >                File
> >             line 1700, in with_ei_usage
> >                File
> >             line 1716, in <lambda>
> >                File
> >                "/soft/python-2.6.1-r1/lib/python2.6/distutils/core.py",
> >                line 152, in setup
> >                  dist.run_commands()
> >                File
> >                "/soft/python-2.6.1-r1/lib/python2.6/distutils/dist.py",
> >                line 975, in run_commands
> >                  self.run_command(cmd)
> >                File
> >                line 995, in run_command
> >                  cmd_obj.run()
> >                File
> >             line 211, in run
> >                File
> >             line 446, in easy_install
> >                File
> >             line 476, in install_item
> >                File
> >             line 655, in install_eggs
> >                File
> >             line 930, in build_and_install
> >                File
> >             line 919, in run_setup
> >                File
> >         "/autonfs/home/davidk/swift-vm-boot/ve/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg/setuptools/sandbox.py",
> >             line 52, in run_setup
> >             AttributeError: 'module' object has no attribute
> >             '__getstate__'
> >                File "bin/virtualenv.py", line 1647, in <module>
> >                  main()
> >                File "bin/virtualenv.py", line 558, in main
> >                  prompt=options.prompt)
> >                File "bin/virtualenv.py", line 656, in
> >                create_environment
> >                  install_pip(py_executable)
> >                File "bin/virtualenv.py", line 415, in install_pip
> >                  filter_stdout=_filter_setup)
> >                File "bin/virtualenv.py", line 624, in
> >                call_subprocess
> >                  % (cmd_desc, proc.returncode))
> >             OSError: Command /autonfs/home/davidk/swift-vm-...ython
> >             failed with error code 1
> >             Failed to created the needed python virtual environment
> >             On Fri, May 20, 2011 at 7:20 PM, John Bresnahan <
> >         <mailto: bresnaha at mcs.anl.gov
> >         <mailto:bresnaha at mcs.anl.gov>> >>
> >             wrote:
> >                 Our phone call today left me motiviated to show you
> >                 guys how easy it is to get
> >         virtual machines
> >                 for use with swift on FutureGrid.
> >                 I made some small scripts around the Nimbus tool
> >                 cloudinitd. The scripts just make
> >         installing
> >                 the software and running it trivial. With a single
> >                 command you can get N VMs from the
> >                 FutureGrid Nimbus clouds (N can be on the order of
> >                 hundreds). When the tool is done
> >         it outputs
> >                 a line separated list of hostnames. All of these
> >                 hostnames have root access
> >         available via your
> >                 ~/.ssh/id_rsa keys.
> >                 If/when you have FutureGrid credentials, untar the
> >                 attachment and give it a try.
> >           There are a
> >                 few minor configurations needed:
> >                 1) edit the file env.sh and set your FutureGrid
> >                 security credentials:
> >                 % cat env.sh
> >                 export FUTUREGRID_IAAS_ACCESS_KEY=XXXXXXXXXXXXXXXXXX
> >                 export
> >                 FUTUREGRID_IAAS_SECRET_KEY=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
> >                 export FUTUREGRID_HOTEL_NODES=2
> >                 export FUTUREGRID_SIERRA_NODES=2
> >                 You can also change the value '2' to be whatever
> >                 number of VMs you want.
> >                 2) install it on your system. (this single command
> >                 downloads and installs
> >         everything you need
> >                 under the cwd):
> >                 % ./install.sh
> >                 3) boot the VMs
> >                 % ./bin/bootit.sh.
> >             You will see much status output, but the last several
> >             lines will be the hostnames
> >         acquired from
> >                 the cloud.
> >                 Let me know when you guys are ready to check this
> >                 out!
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
