[Swift-devel] queuedsize > 0 but no job dequeued
Mihael Hategan hategan at mcs.anl.gov
Tue Aug 30 15:05:54 CDT 2011
Any chance you can re-run this with debug enabled on coasters
(log4j.logger.org.globus.cog.abstraction.coaster=DEBUG)?
On Mon, 2011-08-29 at 20:55 -0700, Mihael Hategan wrote:
> My bad. The info is in the swift log.
> On Mon, 2011-08-29 at 20:59 -0500, Ketan Maheshwari wrote:
> > This is on Beagle. I am running local:pbs from /lustre.
> > On Mon, Aug 29, 2011 at 8:30 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> >         On Mon, 2011-08-29 at 19:52 -0500, Ketan Maheshwari wrote:
> >         > Mihael,
> >         > This run was with automatic coasters. I do not see any
> >         specific
> >         > coasters.log file written during this run in .globus/coaster
> >         nor in
> >         > the run's work dir.
> >         It's on the remote site in .globus/coasters.
> >         > Ketan
> >         > On Mon, Aug 29, 2011 at 7:16 PM, Mihael Hategan
> >         > wrote:
> >         >         Can I have the coasters log please?
> >         >         On Sun, 2011-08-28 at 16:47 -0500, Ketan Maheshwari
> >         wrote:
> >         >         > Hello,
> >         >         > I remember this error happened in the past with
> >         Glen's and
> >         >         Sheri's
> >         >         > runs. I saw this today again on Beagle with 0.93
> >         while
> >         >         running the
> >         >         > DSSAT run.
> >         >         > The run stops with the following complete message:
> >         >         > queuedsize > 0 but no job dequeued. Queued: {}
> >         >         > java.lang.Throwable
> >         >         >     at
> >         org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:269)
> >         >         >     at
> >         org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:539)
> >         >         >     at
> >         org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:110)
> >         >         > java.lang.Throwable
> >         >         >     at
> >         >         >     at
> >         >         >     at
> >         >         > Progress:  time: Sun, 28 Aug 2011 13:34:26 -0600
> >         >          Submitted:76
> >         >         >  Active:23  Checking status:1  Finished
> >         successfully:597
> >         >         > The logs, properties and sources for this run are:
> >         >         > http://www.ci.uchicago.edu/~ketan/run23.tgz
> >         >         > Regards,
> >         >         > Ketan
> >         >         > _______________________________________________
> >         >         > Swift-devel mailing list
> >         >         > Swift-devel at ci.uchicago.edu
> >         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >         > Ketan
> > Ketan
