[Swift-devel] May need VOMS proxy for many OSG sites
Ben Clifford benc at hawaga.org.uk
Thu Jun 17 11:46:28 CDT 2010
this was my understanding when I left:
i) anywhere that takes a grid-proxy-init proxy will take a voms-proxy-init
proxy, as brian bockelman notes.
ii) a voms proxy is a grid proxy with an additional annotation, as you
describe.
iii) osg sites which use grid map files will generally accept either kind.
osg sites which use VOMS directly require a voms proxy.
iv) I considered the issue of packaging voms-proxy-init in the broader
context of making swift work in harmony with the OSG software stack. To
that end, I experimented with making swift installable through pacman (one
of the earlier releases has that noted on the download page, I think) so
that you could install it along with an osg stack. That would give you,
for example, voms-proxy-init, but also things like OSG's CA collection.
http://www.hawaga.org.uk/ben/
