[Swift-devel] feature request
Zhao Zhang zhaozhang at uchicago.edu
Thu Apr 23 12:20:12 CDT 2009
Hi, again
the test on teraport is successful, here is the log
zhao
testing site configuration: coaster/teraport-gt2-gt2-pbs.xml
Removing files from previous runs
Running test 061-cattwo at Thu Apr 23 11:27:19 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090423-1127-aluxx4m9
Progress:
Progress:  Stage in:1
Progress:  Submitted:1
Progress:  Active:1
Progress:  Finished successfully:1
Final status:  Finished successfully:1
Cleaning up...
Shutting down service at https://128.135.125.118:57080
Got channel MetaChannel: 2129305 -> GSSSChannel-null(1)
- Done
expecting 061-cattwo.out.expected
checking 061-cattwo.out.expected
Skipping exception test due to test configuration
Test passed at Thu Apr 23 11:57:39 CDT 2009
Running test 130-fmri at Thu Apr 23 11:57:39 CDT 2009
RunID: 20090423-1157-r8sarc77
Progress:
Progress:  Selecting site:2  Initializing site shared directory:1  Stage
in:1
Progress:  Selecting site:2  Stage in:1  Submitting:1
Progress:  Selecting site:2  Submitting:1  Submitted:1
Progress:  Selecting site:2  Submitted:2
Progress:  Selecting site:2  Submitted:1  Active:1
Progress:  Selecting site:2  Active:1  Stage out:1
Progress:  Selecting site:1  Stage in:1  Stage out:1  Finished
successfully:1
Progress:  Submitted:1  Stage out:1  Finished successfully:2
Progress:  Active:1  Finished successfully:4
Progress:  Submitting:2  Submitted:1  Finished successfully:5
Progress:  Active:2  Stage out:1  Finished successfully:5
Progress:  Submitted:1  Stage out:2  Finished successfully:8
Final status:  Finished successfully:11
Cleaning up...
Shutting down service at https://128.135.125.118:52773
Got channel MetaChannel: 28761475 -> GSSSChannel-null(1)
- Done
expecting 130-fmri.0000.jpeg.expected 130-fmri.0001.jpeg.expected
130-fmri.0002.jpeg.expected
checking 130-fmri.0000.jpeg.expected
checking 130-fmri.0001.jpeg.expected
checking 130-fmri.0002.jpeg.expected
Test passed at Thu Apr 23 12:04:47 CDT 2009
Running test 103-quote at Thu Apr 23 12:04:47 CDT 2009
RunID: 20090423-1204-sjzpkfd3
Progress:
Progress:  Active:1
Cleaning up...
Shutting down service at https://128.135.125.118:40813
Got channel MetaChannel: 28500325 -> GSSSChannel-null(1)
- Done
expecting 103-quote.out.expected
checking 103-quote.out.expected
Test passed at Thu Apr 23 12:05:05 CDT 2009
Running test 1032-singlequote at Thu Apr 23 12:05:05 CDT 2009
RunID: 20090423-1205-x2d55af3
Progress:
Progress:  Active:1
Cleaning up...
Shutting down service at https://128.135.125.118:44126
Got channel MetaChannel: 18100302 -> GSSSChannel-null(1)
- Done
expecting 1032-singlequote.out.expected
checking 1032-singlequote.out.expected
Test passed at Thu Apr 23 12:05:22 CDT 2009
Running test 1031-quote at Thu Apr 23 12:05:22 CDT 2009
RunID: 20090423-1205-5aa1ko4e
Progress:
Progress:  Active:1
Cleaning up...
Shutting down service at https://128.135.125.118:43759
Got channel MetaChannel: 19002607 -> GSSSChannel-null(1)
- Done
expecting 1031-quote.*.expected
No expected output files specified for this test case - not checking output.
Test passed at Thu Apr 23 12:05:38 CDT 2009
Running test 1033-singlequote at Thu Apr 23 12:05:38 CDT 2009
RunID: 20090423-1205-8nopyujc
Progress:
Progress:  Active:1
Cleaning up...
Shutting down service at https://128.135.125.118:39924
Got channel MetaChannel: 31196317 -> GSSSChannel-null(1)
- Done
expecting 1033-singlequote.out.expected
checking 1033-singlequote.out.expected
Test passed at Thu Apr 23 12:05:56 CDT 2009
Running test 141-space-in-filename at Thu Apr 23 12:05:56 CDT 2009
RunID: 20090423-1205-aalqz1c4
Progress:
Progress:  Active:1
Cleaning up...
Shutting down service at https://128.135.125.118:60177
Got channel MetaChannel: 4728458 -> GSSSChannel-null(1)
- Done
expecting 141-space-in-filename.space here.out.expected
checking 141-space-in-filename.space here.out.expected
Test passed at Thu Apr 23 12:06:15 CDT 2009
Running test 142-space-and-quotes at Thu Apr 23 12:06:15 CDT 2009
RunID: 20090423-1206-8617gag1
Progress:
in:1
Progress:  Selecting site:2  Active:1  Finished successfully:1
Progress:  Stage out:1  Finished successfully:3
Final status:  Finished successfully:4
Cleaning up...
Shutting down service at https://128.135.125.118:57945
Got channel MetaChannel: 16387060 -> GSSSChannel-null(1)
- Done
expecting 142-space-and-quotes.2" space ".out.expected
142-space-and-quotes.3' space '.out.expected
142-space-and-quotes.out.expected 142-space-and-quotes. space .out.expected
checking 142-space-and-quotes.2" space ".out.expected
checking 142-space-and-quotes.3' space '.out.expected
checking 142-space-and-quotes.out.expected
checking 142-space-and-quotes. space .out.expected
Test passed at Thu Apr 23 12:06:35 CDT 2009
All language behaviour tests passed
Zhao Zhang wrote:
> Hi, Ben
> Ben Clifford wrote:
>> On Thu, 23 Apr 2009, Zhao Zhang wrote:
>>> Error 1: This is related to CI network setting,
>>> /etc/grid-security/hostcert.pem. Could anyone help on this? Who
>>> should I
>>> contact?
>> fletch is broken. But try changing those sites files to use
>> gwynn.bsd.uchicago.edu instead.
>>> Error 2: My certificate is not enabled on teraport, As Mike and I
>>> talked last
>>> night, "certificate revocation list" on CI network is misconfigured.
>> This looks more like a permissions problem - the directory being used
>> in the sites.xml file for that test does not exist and you do not
>> have permission to create it.
>> In r2874 I have changes tests/sites/coaster/teraport-gt2-gt2-pbs.xml
>> to use a different path that should work for you now.
> I tried this out, it failed, then I increased the wall-time to 15
> minutes in the coaster/teraport-gt2-gt2-pbs.xml  file.
> And I am waiting now.
> zhao
> [zzhang at communicado sites]$ ./run-site coaster/teraport-gt2-gt2-pbs.xml
> Running test 061-cattwo at Thu Apr 23 11:12:09 CDT 2009
> RunID: 20090423-1112-6jqlxfcf
> Progress:
> Failed to transfer wrapper log from
> 061-cattwo-20090423-1112-6jqlxfcf/info/q on teraport
> 061-cattwo-20090423-1112-6jqlxfcf/info/s on teraport
> 061-cattwo-20090423-1112-6jqlxfcf/info/u on teraport
> Progress:  Failed:1
> Execution failed:
>        Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: teraport
> Directory: 061-cattwo-20090423-1112-6jqlxfcf/jobs/u/cat-umlmrs9j
> stderr.txt:
> stdout.txt:
> Caused by:
>        Job cannot be run with the given max walltime worker constraint
> (task: 600, maxwalltime: 300s)
> Cleaning up...
> Shutting down service at https://128.135.125.118:58204
> Got channel MetaChannel: 1297642 -> GSSSChannel-null(1)
> - Done
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>>> Error 3 & Error 4: I am not active on tgncsa site. Mike said he
>>> needed to add
>>> me to another group.
>> yes.
>> Do you have the list from the end of your test run about which sites
>> worked and which did not?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
