[Swift-devel] could swift use return code from falkon as a success notification?
Mihael Hategan hategan at mcs.anl.gov
Thu Oct 2 14:42:46 CDT 2008
It would be useful if you could post the logs.
On Thu, 2008-10-02 at 14:37 -0500, Zhao Zhang wrote:
> After applying the patch, I rebuild falkon, and run the tests. It failed.
> zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk/tests/misc> ./run
> Removing files from previous runs
> Running test 130-fmri
> Swift svn swift-r2169 (Swift modified locally) cog-r2125
> RunID: 20081002-1429-v0e0f3a3
> Progress:
> touch started
> touch started
> touch started
> touch started
> Sorted: [localhost:0.000(1.000):0/1 overload: 0]
> Sorted: [localhost:0.000(1.000):1/1 overload: 0]
> Failed to transfer wrapper log from
> 130-fmri-20081002-1429-v0e0f3a3/info/4/localhost
> 130-fmri-20081002-1429-v0e0f3a3/info/3/localhost
> Sorted: [localhost:-2.500(0.257):0/1 overload: 0]
> 130-fmri-20081002-1429-v0e0f3a3/info/7/localhost
> Sorted: [localhost:-4.200(0.129):0/1 overload: 0]
> Progress:  Stage in:1 Failed but can retry:3
> 130-fmri-20081002-1429-v0e0f3a3/info/9/localhost
> Sorted: [localhost:-5.900(0.079):0/1 overload: 0]
> 130-fmri-20081002-1429-v0e0f3a3/info/b/localhost
> SWIFT RETURN CODE NON-ZERO
> test clusters ended with return value 1
> zhao
> Ben Clifford wrote:
> > ok, try the same compiled code with the localhost provider running those
> > tests. If those pass, then there may be something not working as necessary
> > in provider-deef or falkon (the step in Mihaels instructions about getting
> > falkon+provider-deef to return process exit codes). If not, then there is
> > some other problem.
> > On Wed, 1 Oct 2008, Zhao Zhang wrote:
> >> Thanks, Ben.
> >> First I tested the tests/misc/run, and it is ok.
> >> Then I applied the patch, then swift failed:
> >> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/n/s/bgp0
> >> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/t/s/bgp0
> >> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/1/t/bgp0
> >> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/0/t/bgp0
> >> sleep failed
> >> sleep failed
> >> sleep failed
> >> Exception in sleep:
> >> Arguments: [30]
> >> Host: bgp0
> >> Directory: sleep-20081001-1558-in93l5j4/jobs/g/s/sleep-gsski80j
> >> stderr.txt:
> >> stdout.txt:
> >> zhao
> >> Ben Clifford wrote:
> >>> I was playing with this last week so have a patch in my stack:
> >>> cd cog/
> >>> wget http://www.ci.uchicago.edu/~benc/return-codes-1
> >>> patch -p1 < ./return-codes-1
> >>> This changes Swift behaviour but does not do anything to provider-deef,
> >>> which might or might not work correctly at the moment.
> >>> Running the tests in tests/misc/ by running ./run in that directory will
> >>> help you test whether its working still or not - check they pass before you
> >>> apply the patch, and then check afterwards too.
