[Swift-devel] exception report
Ben Clifford benc at hawaga.org.uk
Fri Nov 14 11:09:03 CST 2008
Hmm. Can you send the source code for your SwiftScript?
I think you might be running into the 'data dependency vs sequential
execution' problem that I've been working to fix recently. But I'd lke to
see your source code.
On Thu, 13 Nov 2008, Zhao Zhang wrote:
> Hi, All
> I got an exception for the swift script on BGP, although it returned
> successful.
> The log file is at
> http://www.ci.uchicago.edu/~zzhang/dock3-20081113-1707-j38zbyp9.log
> The swift script is at http://www.ci.uchicago.edu/~zzhang/dock3.swift
> zhao
> zzhang at login6.surveyor:~/swift/test> ./run_swift.sh 0754 64 dock3.swift `pwd`
> waiting for at least 64 nodes to register before submitting workload...
> waiting to find at least 1 services in file
> /home/falkon/users/zzhang/0754/config/Client-service-URIs.config...
> all done, file has found at least 1 services
> found at least 64 registered, submitting workload...
> Swift svn swift-r2249 (Swift modified locally) cog-r2216
> RunID: 20081113-1707-j38zbyp9
> Progress:
> org.griphyn.vdl.karajan.VDL2FutureException
>        at
> org.griphyn.vdl.mapping.MappingParam.checkHandle(MappingParam.java:74)
>        at org.griphyn.vdl.mapping.MappingParam.getValue(MappingParam.java:46)
>        at
> org.griphyn.vdl.mapping.MappingParam.getStringValue(MappingParam.java:82)
>        at
> org.griphyn.vdl.mapping.file.SingleFileMapper.existing(SingleFileMapper.java:24)
>        at
> org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:67)
>        at
> org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:48)
>        at org.griphyn.vdl.mapping.RootDataNode.init(RootDataNode.java:38)
>        at org.griphyn.vdl.karajan.lib.New.function(New.java:127)
>        at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:65)
>        at
> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java(Inlined
> Compiled Code))
>        at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java(Compiled
> Code))
>        at
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.user.UserDefinedElement.childCompleted(UserDefinedElement.java:283)
>        at
> org.globus.cog.karajan.workflow.nodes.user.SequentialImplicitExecutionUDE.childCompleted(SequentialImplicitExecutionUDE.java:85)
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Compiled Code))
>        at
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.functions.Argument.post(Argument.java:45)
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Compiled Code))
>        at
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.functions.Map_Map.post(Map_Map.java:55)
>        at
> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.Sequential.childCompleted(Sequential.java:45)
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Compiled Code))
>        at
> Code))
>        at org.globus.cog.karajan.workflow.nodes.Each.post(Each.java:31)
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Code))
>        at
> Compiled Code))
>        at
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
>        at
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
>        at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java(Compiled
> Code))
>        at
> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java(Inlined
> Compiled Code))
>        at
> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java(Compiled
> Code))
>        at
> Code))
>        at
> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java(Compiled
> Code))
>        at
> Code))
>        at
> Code))
>        at
> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
