[Swift-devel] proper way to run swift on resource using condor?
Ian Foster foster at mcs.anl.gov
Tue May 20 21:31:33 CDT 2008
Again, why don't you use a GRAM submit as you would at any other TG
site?
On May 20, 2008, at 9:23 PM, Mike Kubal wrote:
> I've been having swift invoke a perl script on Purdue.
> The perl script writes the the descriptor file that is
> passed as an argument to the condor_submit command
> within the perl script. The condor_submit command
> actually launches the job on a compute node. Every 30
> seconds the perl script checks to see if the launched
> job has finished. When the launched job finishes the
> perl script ends, and the result files are returned
> via swift.  The problem with this approach is that I
> am either piling many perl scripts onto the logon node
> or wasting a compute node to just check the status of
> the job.
> I have experimented with having swift call
> condor_submit directly with the idea of having a
> single separate swift function check the status of all
> jobs and returned the result files when finished. The
> problem here is that once the the job has been
> launched successfully, swift removes the  job
> sub-directory where the results of the job launched
> via condor_submit are written.
> Suggestions welcome,
> Mike
> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
>> Are you referring to the arguments-with-spaces
>> issue?
>> On Tue, 2008-05-20 at 14:46 -0700, Mike Kubal wrote:
>>> I have been using some 'work around' methods to
>> use
>>> Swift to run jobs on  the Purdue resource that
>> uses
>>> Condor. Is there a proper way?
>>> Thanks,
>>> Mike
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
