[Swift-devel] mystery runs on ucanl
skenny at uchicago.edu skenny at uchicago.edu
Tue Jul 29 16:45:59 CDT 2008
>This looks like you're trying to run ia64 code on an ia32
machine.
>Double verify that you are in fact requesting the right type
of node
>(ia64-compute for ia64 and ia32-compute for ia32). If you
don't, you
>will arbitrarily be placed on an available node, which could
be either
>architecture.
hi ti, i understand that; however the issue seems to be that
even when the job makes it to an ia64 node it dies...in
particular it seems tg-c054 might be problematic. is there a
way i can submit directly to this node to test it?
