[Swift-devel] numeric type(s) in swift.
Mihael Hategan hategan at mcs.anl.gov
Tue Jul 24 15:12:28 CDT 2007
I've committed some stuff to that branch which should make the numeric
operators more efficient. The language behavior tests seem to pass.
One potentially problem-causing change (if broken code makes broken
assumptions) is that Swift number values are not stored as strings any
more, but as subclasses of java.lang.Number.
Mihael
On Fri, 2007-07-20 at 22:12 +0000, Ben Clifford wrote:
> I made a branch with the relevant patches from my quilt patch stack.
> https://svn.ci.uchicago.edu/svn/vdl2/branches/types-and-expressions
> In r940, I remove non-integer numbers from by language by virtue of
> removing the test cases from language-behaviour for them (but no actual
> code changes). If you want to run the language-behaviour tests with the
> non-integer tests in there again, roll back r940 in your local repo.
> The two biggest changes are r941 which makes much more stuff be wrapped in
> DSHandles, and r942 which is adjustment to the intermediate language to
> have XML based expressions.
> As a consequence of r942, the resulting karajan code has a lot more cruft
> in it (but should still behave as previously). I'm intending to work on
> that more so don't be alarmed.
> Type this for the commit logs so far:
> svn log
> -r933:HEAD
