[Swift-commit] r8381 - SwiftApps/subjobs/mpicatsnsleep
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Fri Feb 27 14:02:44 CST 2015
Author: ketan
Date: 2015-02-27 14:02:44 -0600 (Fri, 27 Feb 2015)
New Revision: 8381
Added:
   SwiftApps/subjobs/mpicatsnsleep/cobalt.cetus.xml
   SwiftApps/subjobs/mpicatsnsleep/data.txt
   SwiftApps/subjobs/mpicatsnsleep/runcetus.sh
Removed:
   SwiftApps/subjobs/mpicatsnsleep/in.data
Modified:
   SwiftApps/subjobs/mpicatsnsleep/catsnsleepmpi.swift
   SwiftApps/subjobs/mpicatsnsleep/runswift.sh
Log:
test on cetus
Modified: SwiftApps/subjobs/mpicatsnsleep/catsnsleepmpi.swift
--- SwiftApps/subjobs/mpicatsnsleep/catsnsleepmpi.swift	2015-02-27 17:10:08 UTC (rev 8380)
+++ SwiftApps/subjobs/mpicatsnsleep/catsnsleepmpi.swift	2015-02-27 20:02:44 UTC (rev 8381)
@@ -2,7 +2,7 @@
 app (file o, file sout, file serr) cat (file i)
-  bgsh "/home/ketan/SwiftApps/subjobs/mpicatnap" @i @o arg("s","1") stdout=@sout stderr=@serr;
+  bgsh "/home/ketan/SwiftApps/subjobs/mpicatsnsleep/mpicatnap" @i @o arg("s","1") stdout=@sout stderr=@serr;
 file out[]<simple_mapper; location="outdir", prefix="f.",suffix=".out">;
Added: SwiftApps/subjobs/mpicatsnsleep/cobalt.cetus.xml
--- SwiftApps/subjobs/mpicatsnsleep/cobalt.cetus.xml	                        (rev 0)
+++ SwiftApps/subjobs/mpicatsnsleep/cobalt.cetus.xml	2015-02-27 20:02:44 UTC (rev 8381)
@@ -0,0 +1,32 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+<pool handle="cluster">
+<execution provider="coaster" jobmanager="local:cobalt" />
+<profile namespace="globus" key="slots">1</profile>
+<profile namespace="globus" key="mode">script</profile>
+<profile namespace="karajan" key="jobThrottle">2.99</profile>
+<profile namespace="karajan" key="initialScore">10000</profile>
+<profile namespace="globus" key="maxwalltime">00:04:00</profile>
+<profile namespace="globus" key="walltime">600</profile>
+<profile namespace="globus" key="maxnodes">32</profile>
+<profile namespace="globus" key="nodegranularity">32</profile>
+<profile key="SUBBLOCK_SIZE" namespace="env">16</profile>
+<profile key="WORKER_LOGGING_LEVEL" namespace="env">DEBUG</profile>
+<profile key="ENABLE_WORKER_LOGGING" namespace="env">TRUE</profile>
+<profile key="ENABLE_WORKER_LOGGING" namespace="env">ON</profile>
+<profile key="WORKER_LOG_DIR" namespace="env">/home/ketan/workerlogs</profile>
+<profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
+<profile namespace="globus" key="workerLoggingDirectory">/home/ketan/workerlogs</profile>
+<profile namespace="globus" key="jobsPerNode">2</profile>
+<workdirectory>/home/ketan/swiftwork</workdirectory>
+<filesystem provider="local"/>
+</pool>
+</config>
Copied: SwiftApps/subjobs/mpicatsnsleep/data.txt (from rev 8380, SwiftApps/subjobs/mpicatsnsleep/in.data)
--- SwiftApps/subjobs/mpicatsnsleep/data.txt	                        (rev 0)
+++ SwiftApps/subjobs/mpicatsnsleep/data.txt	2015-02-27 20:02:44 UTC (rev 8381)
@@ -0,0 +1 @@
+this is my input
Deleted: SwiftApps/subjobs/mpicatsnsleep/in.data
--- SwiftApps/subjobs/mpicatsnsleep/in.data	2015-02-27 17:10:08 UTC (rev 8380)
+++ SwiftApps/subjobs/mpicatsnsleep/in.data	2015-02-27 20:02:44 UTC (rev 8381)
@@ -1 +0,0 @@
-this is my input
Added: SwiftApps/subjobs/mpicatsnsleep/runcetus.sh
--- SwiftApps/subjobs/mpicatsnsleep/runcetus.sh	                        (rev 0)
+++ SwiftApps/subjobs/mpicatsnsleep/runcetus.sh	2015-02-27 20:02:44 UTC (rev 8381)
@@ -0,0 +1,13 @@
+#! /bin/sh
+#Old method
+#qsub -A ATPESC2014 -n 512 -t 15 --mode script runswift_script.sh -config cf -tc.file apps -sites.file localcoast.xml "$@"
+#build app
+#mpixlc mpicatnap.c -o mpicatnap
+#New method
+/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift -sites.file cobalt.cetus.xml -config cf -tc.file apps catsnsleepmpi.swift -n=16 -s=1
+#A testblock run
+#qsub -A ATPESC2013 -n 32 -t 5 -q low --mode c16 --mode script testblock.sh # --disable_preboot
Property changes on: SwiftApps/subjobs/mpicatsnsleep/runcetus.sh
___________________________________________________________________
Added: svn:executable
Modified: SwiftApps/subjobs/mpicatsnsleep/runswift.sh
--- SwiftApps/subjobs/mpicatsnsleep/runswift.sh	2015-02-27 17:10:08 UTC (rev 8380)
+++ SwiftApps/subjobs/mpicatsnsleep/runswift.sh	2015-02-27 20:02:44 UTC (rev 8381)
@@ -7,7 +7,7 @@
 #New method
-/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift -sites.file cobalt.xml -config cf -tc.file apps catsnsleepmpi.swift -n=64 -s=2
+/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift -sites.file cobalt.xml -config cf -tc.file apps catsnsleepmpi.swift -n=16 -s=1
 #A testblock run
