[Swift-commit] r8471 - www/Swift-T
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Mon Aug 3 12:15:47 CDT 2015
Author: wozniak
Date: 2015-08-03 12:15:46 -0500 (Mon, 03 Aug 2015)
New Revision: 8471
Modified:
   www/Swift-T/turbine-sites.html
Log:
Update Beagle notes
Modified: www/Swift-T/turbine-sites.html
--- www/Swift-T/turbine-sites.html	2015-07-27 15:48:26 UTC (rev 8470)
+++ www/Swift-T/turbine-sites.html	2015-08-03 17:15:46 UTC (rev 8471)
@@ -746,7 +746,7 @@
 <span id="author">Justin M. Wozniak</span><br />
 <span id="email"><code><<a href="mailto:wozniak at mcs.anl.gov">wozniak at mcs.anl.gov</a>></code></span><br />
 <span id="revnumber">version 0.8.0,</span>
-<span id="revdate">March 2015</span>
+<span id="revdate">August 2015</span>
 <div id="toc">
   <div id="toctitle">Table of Contents</div>
   <noscript><p><b>JavaScript must be enabled in your browser to display the table of contents.</b></p></noscript>
@@ -2126,17 +2126,17 @@
 <div class="ulist"><ul>
 <li>
 <p>
-Swift/T trunk - 6/11/2013
+Swift/T master - 8/3/2015
 </p>
 </li>
 <li>
 <p>
-Turbine: <code>~wozniak/Public/turbine-trunk-beagle-login</code>
+Turbine: <code>~wozniak/Public/sfw/x86_64/swift-t/turbine</code>
 </p>
 </li>
 <li>
 <p>
-STC: <code>~wozniak/Public/stc-trunk-beagle-login</code>
+STC: <code>~wozniak/Public/sfw/x86_64/swift-t/</code>
 </p>
 </li>
 </ul></div>
@@ -2146,19 +2146,24 @@
 <li>
 <p>
+Swift/T trunk - 8/3/2015
 </p>
 </li>
 <li>
 <p>
-Turbine: <code>/lustre/beagle/wozniak/Public/turbine</code>
+Turbine: <code>~wozniak/Public/sfw/beagle/swift-t/turbine</code>
 </p>
 </li>
 <li>
 <p>
-STC: <code>/lustre/beagle/wozniak/Public/stc</code>
+STC: <code>~wozniak/Public/sfw/beagle/swift-t/</code>
 </p>
 </li>
+<li>
+<p>
+This installation is configured with <a href="http://swift-lang.org/Swift-T/guide.html#_calling_python">Python</a>
+</p>
+</li>
 </ul></div>
 <div class="paragraph"><p>To run:</p></div>
 <div class="olist arabic"><ol class="arabic">
@@ -2170,12 +2175,24 @@
 </li>
 <li>
 <p>
-Run submit script (in <code>turbine/scripts/submit/cray</code>):
+Run Swift:
 </p>
 <div class="listingblock">
 <div class="content">
-<pre><code>turbine-aprun-run.zsh -n <numprocs> script.tcl --arg1=value1 ...</code></pre>
+<pre><code>swift-t -m cray -n <numprocs> script.swift --arg1=value1 ...</code></pre>
 </div></div>
+<div class="paragraph"><p>or:</p></div>
+<div class="paragraph"><p>Run Turbine:</p></div>
+<div class="listingblock">
+<div class="content">
+<pre><code>turbine -m cray -n <numprocs> script.tic --arg1=value1 ...</code></pre>
+</div></div>
+<div class="paragraph"><p>Run the submit script directly (in <code>turbine/scripts/submit/cray</code>):</p></div>
+<pre><code>turbine-cray-run.zsh -n <numprocs> script.tic --arg1=value1 ...</code></pre>
+</div></div>
 </li>
 </ol></div>
 </div>
@@ -2202,7 +2219,7 @@
 </p>
-<pre><code>--enable-custom-mpi --with-mpi=/opt/cray/mpt/default/gni/mpich2-gnu/49</code></pre>
+<pre><code>--with-mpi=/opt/cray/mpt/default/gni/mpich2-gnu/49</code></pre>
 </div></div>
 </li>
 </ul></div>
@@ -2696,7 +2713,7 @@
 <div id="footer">
 <div id="footer-text">
 Version 0.8.0<br />
-Last updated 2015-07-23 16:57:11 CDT
+Last updated 2015-08-03 12:15:04 CDT
 </div>
 </div>
 </body>
