[Swift-commit] r8256 - SwiftApps/subjobs
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon Sep 29 09:53:02 CDT 2014
Author: ketan
Date: 2014-09-29 09:53:02 -0500 (Mon, 29 Sep 2014)
New Revision: 8256
Modified:
   SwiftApps/subjobs/bg.sh
   SwiftApps/subjobs/runswift.sh
Log:
old changes
Modified: SwiftApps/subjobs/bg.sh
--- SwiftApps/subjobs/bg.sh	2014-09-29 14:52:51 UTC (rev 8255)
+++ SwiftApps/subjobs/bg.sh	2014-09-29 14:53:02 UTC (rev 8256)
@@ -28,7 +28,7 @@
 export SWIFT_SUBBLOCKS=$(get-corners.py "$COBALT_PARTNAME" $SHAPE)
 export SWIFT_SUBBLOCK_ARRAY=($SWIFT_SUBBLOCKS)
-echo "$0": SWIFT_SUBBLOCKS="$SWIFT_SUBBLOCKS"
+#echo "$0": SWIFT_SUBBLOCKS="$SWIFT_SUBBLOCKS"
 if [ "_$SWIFT_SUBBLOCKS" = _ ]; then
   echo ERROR: "$0": SWIFT_SUBBLOCKS is null.
@@ -36,10 +36,6 @@
 fi
 nsb=${#SWIFT_SUBBLOCK_ARRAY[@]}
-for ((sb=0;sb<nsb;sb++))
-do
-  echo "$0: SUBBLOCK $sb: ${SWIFT_SUBBLOCK_ARRAY[$sb]}"
-done
 CORNER=${SWIFT_SUBBLOCK_ARRAY[$SWIFT_JOB_SLOT]}
@@ -47,9 +43,6 @@
 echo "$0": running cmd: "$0" args: "$@"
 echo "$0": running runjob  --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" --ranks-per-node 1 : "$REMAINING_ARGS"
-#with timeout
-#runjob --strace 0 --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 1 --np "$SUBBLOCK_SIZE" --timeout 100 : "$@"
 #without timeout
 runjob --strace 0 --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 1 --np "$SUBBLOCK_SIZE" : "$@"
Modified: SwiftApps/subjobs/runswift.sh
--- SwiftApps/subjobs/runswift.sh	2014-09-29 14:52:51 UTC (rev 8255)
+++ SwiftApps/subjobs/runswift.sh	2014-09-29 14:53:02 UTC (rev 8256)
@@ -7,7 +7,7 @@
 mpixlc mpicatnap.c -o mpicatnap
 #New method
-/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift -sites.file cobalt.xml -config cf -tc.file apps catsnsleepmpi.swift -n=300 -s=60
+/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift -sites.file cobalt.xml -config cf -tc.file apps catsnsleepmpi.swift -n=600 -s=200
 #A testblock run
 #qsub -A ATPESC2013 -n 32 -t 5 -q low --mode c16 --mode script testblock.sh # --disable_preboot
