[Swift-commit] r8238 - SwiftApps/subjobs
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Tue Sep 9 12:53:59 CDT 2014
Author: ketan
Date: 2014-09-09 12:53:59 -0500 (Tue, 09 Sep 2014)
New Revision: 8238
Added:
   SwiftApps/subjobs/subjob.sh
Modified:
   SwiftApps/subjobs/runbash.sh
Log:
outer script
Modified: SwiftApps/subjobs/runbash.sh
--- SwiftApps/subjobs/runbash.sh	2014-09-09 17:51:57 UTC (rev 8237)
+++ SwiftApps/subjobs/runbash.sh	2014-09-09 17:53:59 UTC (rev 8238)
@@ -1,46 +1,5 @@
 #!/bin/bash
 #To run:
-#qsub -n 256 -t 45 --mode script runbash.sh
+qsub -n 256 -t 45 --mode script subjob.sh
-# Note: This path is for Cetus only
-#export PATH=/soft/cobalt/cetus/bgq_hardware_mapper:$PATH
-# Note: This path is for Mira or Vesta
-export PATH=/soft/cobalt/bgq_hardware_mapper:$PATH
-#build app
-mpixlc mpicatnap.c -o mpicatnap
-SHAPE="1x2x2x2x1"
-CORNERS=$(get-corners.py $COBALT_PARTNAME $SHAPE)
-# Set this low for testing.
-# Consult with systems if you need it > 128
-MAXRUNJOB=64
-i=0
-for j in $(seq 1 200)
-do
-  for CORNER in $CORNERS
-   do
-     echo "Run $i corner $CORNER"
-     stime=$(shuf -i 1-10 -n 1)
-     runjob --block $COBALT_PARTNAME --corner $CORNER --shape $SHAPE -p 1 --np 8 --timeout 30 : mpicatnap in.data out.data $stime >RUNJOB.$j-$i 2>&1 &
-     # Important - give some time for runjob to get initialized
-     sleep 6
-     i=$((i+1))
-     if [ $i -ge $MAXRUNJOB ]; then
-       echo "Reached MAXRUNJOB $MAXRUNJOB"
-       break;
-     fi
-  done
-  # The runjobs were backgrounded, wait for them to finish
-  wait
-  echo "Done $i"
-  i=0
-done
-# Cobalt job ends when this script exits
-exit 0
Added: SwiftApps/subjobs/subjob.sh
--- SwiftApps/subjobs/subjob.sh	                        (rev 0)
+++ SwiftApps/subjobs/subjob.sh	2014-09-09 17:53:59 UTC (rev 8238)
@@ -0,0 +1,46 @@
+#!/bin/bash
+#To run:
+#qsub -n 256 -t 45 --mode script runbash.sh
+# Note: This path is for Cetus only
+#export PATH=/soft/cobalt/cetus/bgq_hardware_mapper:$PATH
+# Note: This path is for Mira or Vesta
+export PATH=/soft/cobalt/bgq_hardware_mapper:$PATH
+#build app
+mpixlc mpicatnap.c -o mpicatnap
+SHAPE="1x2x2x2x1"
+CORNERS=$(get-corners.py $COBALT_PARTNAME $SHAPE)
+# Set this low for testing.
+# Consult with systems if you need it > 128
+MAXRUNJOB=64
+i=0
+for j in $(seq 1 200)
+do
+  for CORNER in $CORNERS
+   do
+     echo "Run $i corner $CORNER"
+     stime=$(shuf -i 1-10 -n 1)
+     runjob --block $COBALT_PARTNAME --corner $CORNER --shape $SHAPE -p 1 --np 8 --timeout 30 : mpicatnap in.data out.data $stime >RUNJOB.$j-$i 2>&1 &
+     # Important - give some time for runjob to get initialized
+     sleep 6
+     i=$((i+1))
+     if [ $i -ge $MAXRUNJOB ]; then
+       echo "Reached MAXRUNJOB $MAXRUNJOB"
+       break;
+     fi
+  done
+  # The runjobs were backgrounded, wait for them to finish
+  wait
+  echo "Done $i"
+  i=0
+done
+# Cobalt job ends when this script exits
+exit 0
Property changes on: SwiftApps/subjobs/subjob.sh
___________________________________________________________________
Added: svn:executable
