[Swift-commit] r8236 - in SwiftApps: . subjobs
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Tue Sep 9 12:49:42 CDT 2014
Author: ketan
Date: 2014-09-09 12:49:41 -0500 (Tue, 09 Sep 2014)
New Revision: 8236
Added:
   SwiftApps/subjobs/
   SwiftApps/subjobs/apps
   SwiftApps/subjobs/bg.sh
   SwiftApps/subjobs/catsnsleepmpi.swift
   SwiftApps/subjobs/cf
   SwiftApps/subjobs/cobalt.xml
   SwiftApps/subjobs/ensemble_jobs_0.pdf
   SwiftApps/subjobs/flexpep.swift
   SwiftApps/subjobs/in.data
   SwiftApps/subjobs/mpicatnap.c
   SwiftApps/subjobs/notes.txt
   SwiftApps/subjobs/runbash.sh
   SwiftApps/subjobs/runswift.sh
Log:
adding subjob dir
Added: SwiftApps/subjobs/apps
--- SwiftApps/subjobs/apps	                        (rev 0)
+++ SwiftApps/subjobs/apps	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,3 @@
+localhost cat /bin/cat null null null
+cluster bgsh /home/ketan/subjoblab/bg.sh null null null
Added: SwiftApps/subjobs/bg.sh
--- SwiftApps/subjobs/bg.sh	                        (rev 0)
+++ SwiftApps/subjobs/bg.sh	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,54 @@
+#! /bin/bash
+# Note: This path is for Cetus only
+#export PATH=/soft/cobalt/cetus/bgq_hardware_mapper:$PATH
+# Note: This path is for Mira or Vesta
+export PATH=/soft/cobalt/bgq_hardware_mapper:$PATH
+case "$SUBBLOCK_SIZE" in
+8) SHAPE="1x2x2x2x1"
+16) SHAPE="2x2x2x2x1"
+32) SHAPE="2x2x2x2x2"
+64) SHAPE="2x2x4x2x2"
+128) SHAPE="2x4x4x2x2"
+256) SHAPE="2x4x4x4x2"
+512) SHAPE="4x4x4x4x2"
+*) SHAPE="2x2x2x2x2"
+   REMAINING_ARGS="$@"
+esac
+export SWIFT_SUBBLOCKS=$(get-corners.py "$COBALT_PARTNAME" $SHAPE)
+export SWIFT_SUBBLOCK_ARRAY=($SWIFT_SUBBLOCKS)
+echo "$0": SWIFT_SUBBLOCKS="$SWIFT_SUBBLOCKS"
+if [ "_$SWIFT_SUBBLOCKS" = _ ]; then
+  echo ERROR: "$0": SWIFT_SUBBLOCKS is null.
+  exit 1
+fi
+nsb=${#SWIFT_SUBBLOCK_ARRAY[@]}
+for ((sb=0;sb<nsb;sb++))
+do
+  echo "$0: SUBBLOCK $sb: ${SWIFT_SUBBLOCK_ARRAY[$sb]}"
+done
+CORNER=${SWIFT_SUBBLOCK_ARRAY[$SWIFT_JOB_SLOT]}
+echo "$0": running BLOCK="$COBALT_PARTNAME" SLOT="$SWIFT_JOB_SLOT"
+echo "$0": running cmd: "$0" args: "$@"
+echo "$0": running runjob  --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" --ranks-per-node 1 : "$REMAINING_ARGS"
+runjob --strace 0 --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 1 --np "$SUBBLOCK_SIZE" --timeout 100 : "$@"
+echo "Runjob finished."
+exit 0
Property changes on: SwiftApps/subjobs/bg.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/subjobs/catsnsleepmpi.swift
--- SwiftApps/subjobs/catsnsleepmpi.swift	                        (rev 0)
+++ SwiftApps/subjobs/catsnsleepmpi.swift	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,15 @@
+type file;
+app (file o, file sout, file serr) cat (file i)
+  bgsh "/home/ketan/subjoblab/mpicatnap" @i @o arg("s","1") stdout=@sout stderr=@serr;
+file out[]<simple_mapper; location="outdir", prefix="f.",suffix=".out">;
+foreach j in [1:toInt(arg("n","1"))] {
+  file data<"data.txt">;
+  file sout<single_file_mapper; file=strcat("outdir/f.",j,".stdout")>;
+  file serr<single_file_mapper; file=strcat("outdir/f.",j,".stderr")>;
+  (out[j],sout,serr) = cat(data);
Added: SwiftApps/subjobs/cf
--- SwiftApps/subjobs/cf	                        (rev 0)
+++ SwiftApps/subjobs/cf	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,27 @@
+wrapperlog.always.transfer=false
+provider.staging.pin.swiftfiles=false
+sitedir.keep=false
+kickstart.always.transfer=false
+replication.limit=3
+throttle.host.submit=2
+clustering.min.time=15
+kickstart.enabled=maybe
+execution.retries=10
+pgraph=false
+use.provider.staging=false
+tracing.enabled=true
+foreach.max.threads=1024
+use.wrapper.staging=false
+replication.enabled=false
+throttle.submit=4
+throttle.score.job.factor=0.2
+lazy.errors=true
+clustering.enabled=false
+caching.algorithm=LRU
+pgraph.node.options=color="seagreen", style="filled"
+replication.min.queue.time=60
+clustering.queue.delay=4
+throttle.file.operations=8
+provenance.log=false
+throttle.transfers=4
+pgraph.graph.options=splines="compound", rankdir="TB"
Added: SwiftApps/subjobs/cobalt.xml
--- SwiftApps/subjobs/cobalt.xml	                        (rev 0)
+++ SwiftApps/subjobs/cobalt.xml	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,24 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+<pool handle="cluster">
+<execution provider="coaster" jobmanager="local:cobalt" />
+<profile namespace="globus" key="slots">1</profile>
+<profile namespace="globus" key="mode">script</profile>
+<profile namespace="karajan" key="jobThrottle">2.99</profile>
+<profile namespace="karajan" key="initialScore">10000</profile>
+<profile namespace="globus" key="maxwalltime">00:40:00</profile>
+<profile namespace="globus" key="walltime">2050</profile>
+<profile namespace="globus" key="maxnodes">256</profile>
+<profile namespace="globus" key="nodegranularity">256</profile>
+<profile key="SUBBLOCK_SIZE" namespace="env">8</profile>
+<profile namespace="globus" key="jobsPerNode">32</profile>
+<workdirectory>/home/ketan/swiftwork</workdirectory>
+<filesystem provider="local"/>
+</pool>
+</config>
Added: SwiftApps/subjobs/ensemble_jobs_0.pdf
(Binary files differ)
Property changes on: SwiftApps/subjobs/ensemble_jobs_0.pdf
Added: svn:mime-type
   + application/octet-stream
Added: SwiftApps/subjobs/flexpep.swift
--- SwiftApps/subjobs/flexpep.swift	                        (rev 0)
+++ SwiftApps/subjobs/flexpep.swift	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,34 @@
+type file;
+app (file _scorefile, file sout, file serr) flexpep (file _pdb)
+  runjob "/projects/ExM/ketan/openmp-gnu-july16-mini/bin/FlexPepDocking.staticmpi.linuxxlcdebug"
+         "-database /home/ketan/minirosetta_database"
+         "-pep_refine" "-s" @_pdb "-ex1" "-ex2aro"
+         "-use_input_sc" "-nstruct" "1" "-overwrite"
+         "-scorefile" @_scorefile
+         stdout=@sout stderr=@serr;
+file scores[] <simple_mapper; location="outdir", prefix="f.",suffix=".sc">;
+file pdb_inputs[] <filesys_mapper; location="/home/ketan/hlac-97-D", pattern="*complex*">;
+foreach pdb, j in pdb_inputs {
+  (scores[j], sout, serr) = flexpep(pdb);
+qsub --env BG_SHAREDMEMSIZE=32MB -t 20 -n 2 --proccount 2  \
+  --mode c1 \
+  /projects/ExM/ketan/openmp-gnu-july16-mini/bin/FlexPepDocking.staticmpi.linuxxlcdebug \
+  -database /home/ketan/minirosetta_database/ \
+  -pep_refine \
+  -s /home/ketan/hlac-97-D/hlac-97-D-AAADAAAAL_complex_0001.pdb \
+  -ex1 \
+  -ex2aro \
+  -use_input_sc \
+  -nstruct 1 -overwrite \
+  -scorefile AAADAAAAL_complex_91R.sc
Added: SwiftApps/subjobs/in.data
--- SwiftApps/subjobs/in.data	                        (rev 0)
+++ SwiftApps/subjobs/in.data	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1 @@
+this is my input
Added: SwiftApps/subjobs/mpicatnap.c
--- SwiftApps/subjobs/mpicatnap.c	                        (rev 0)
+++ SwiftApps/subjobs/mpicatnap.c	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,45 @@
+#include <stdio.h>
+#include <mpi.h>
+#include <unistd.h>
+#include <fcntl.h>
+int main (argc, argv)
+int argc;
+char *argv[];
+  int rank, size;
+  MPI_Init (&argc, &argv);  /* starts MPI */
+  char *ifile = argv[1];
+  char *ofile = argv[2];
+  int sleeptime = atoi(argv[3]);
+  MPI_Comm_rank (MPI_COMM_WORLD, &rank); /* get current MPI process id (rank) */
+  MPI_Comm_size (MPI_COMM_WORLD, &size); /* get number of MPI processes */
+  if (rank==0) {
+    printf("ifile=%s ofile=%s sleeptime=%d\n", ifile, ofile, sleeptime);
+    int ifd = open(ifile,O_RDONLY);
+    int ofd = open(ofile,O_WRONLY|O_CREAT,0664);
+    char buf[1024*1024];
+    for(;;) {
+      int rc = read(ifd, buf, sizeof(buf));
+      if (rc <= 0) {
+        close(ifd);
+        close(ofd);
+        break;
+      write(ofd, buf, rc);
+  sleep(sleeptime);
+  char host[512];
+  gethostname(host, 512);
+  printf( "Hello from process %d of %d on %s\n", rank, size, host);
+  MPI_Finalize();
+  return 0;
Added: SwiftApps/subjobs/notes.txt
--- SwiftApps/subjobs/notes.txt	                        (rev 0)
+++ SwiftApps/subjobs/notes.txt	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,42 @@
+== Sub-block jobs ==
+== Components ==
+Outer block
+Inner blocks
+Parameters
+Blockname
+Blockshape
+Corner
+== Open Issues ==
+== Possible applications ==
+-- xstack mantivo and proxy by Mike Baru from los alamos
+-- Bill Gropp Mlife game
+-- XMatix Coehmm Justin MPI code
+-- Gromacs, NAMD and LAMMPS
+== ToDo ==
+robustness testing
+multiple cobalt jobs ("slots")
+multiple sites each with unique subblock sizes
+docs/tutorials
+persistent coasters
+conversion from 0.95 to trunk
+Use the "direct" mode
+cray
+integ runsubjob into swiftwrap and/or worker.pl (initially, swiftwrap)
+(low prio)
+all above, but for swift/t
+separate: ksub/kstat; same but through sockets? ipython tools?
Added: SwiftApps/subjobs/runbash.sh
--- SwiftApps/subjobs/runbash.sh	                        (rev 0)
+++ SwiftApps/subjobs/runbash.sh	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,43 @@
+#!/bin/bash
+#To run:
+#qsub -n 256 -t 45 --mode script runbash.sh
+SHAPE="1x2x2x2x1"
+CORNERS=$(get-corners.py $COBALT_PARTNAME $SHAPE)
+# Set this low for testing.
+# Consult with systems if you need it > 128
+MAXRUNJOB=64
+i=0
+for j in $(seq 1 200)
+do
+  for CORNER in $CORNERS
+   do
+     echo "Run $i corner $CORNER"
+     stime=$(shuf -i 1-10 -n 1)
+     runjob --block $COBALT_PARTNAME --corner $CORNER --shape $SHAPE -p 1 --np 8 --timeout 30 : mpicatnap in.data out.data $stime >RUNJOB.$j-$i 2>&1 &
+     # Important - give some time for runjob to get initialized
+     sleep 6
+     i=$((i+1))
+     if [ $i -ge $MAXRUNJOB ]; then
+       echo "Reached MAXRUNJOB $MAXRUNJOB"
+       break;
+     fi
+  done
+  # The runjobs were backgrounded, wait for them to finish
+  wait
+  echo "Done $i"
+  i=0
+done
+# Cobalt job ends when this script exits
+exit 0
Property changes on: SwiftApps/subjobs/runbash.sh
Added: SwiftApps/subjobs/runswift.sh
--- SwiftApps/subjobs/runswift.sh	                        (rev 0)
+++ SwiftApps/subjobs/runswift.sh	2014-09-09 17:49:41 UTC (rev 8236)
@@ -0,0 +1,11 @@
+#! /bin/sh
+#Old method
+#qsub -A ATPESC2014 -n 512 -t 15 --mode script runswift_script.sh -config cf -tc.file apps -sites.file localcoast.xml "$@"
+#New method
+~/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift -sites.file cobalt.xml -config cf -tc.file apps catsnsleepmpi.swift -n=32
+#~/prebuilt/swift-devel/cog/modules/swift/dist/swift-svn/bin/swift catsnsleepmpi.swift -n=10
+#A testblock run
+#qsub -A ATPESC2013 -n 32 -t 5 -q low --mode c16 --mode script testblock.sh # --disable_preboot
Property changes on: SwiftApps/subjobs/runswift.sh
