[Swift-commit] r8295 - usertools/plotter/src/plotter
    wozniak at ci.uchicago.edu
    Fri Oct 31 15:56:51 CDT 2014
Author: wozniak
Date: 2014-10-31 15:56:50 -0500 (Fri, 31 Oct 2014)
New Revision: 8295
Modified:
   usertools/plotter/src/plotter/Lines.java
Log:
Features for legend position
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java	2014-10-31 20:56:33 UTC (rev 8294)
+++ usertools/plotter/src/plotter/Lines.java	2014-10-31 20:56:50 UTC (rev 8295)
@@ -23,10 +23,12 @@
 import org.jfree.chart.plot.PlotOrientation;
 import org.jfree.chart.plot.XYPlot;
 import org.jfree.chart.renderer.xy.XYLineAndShapeRenderer;
+import org.jfree.chart.title.LegendTitle;
 import org.jfree.data.Range;
 import org.jfree.data.general.Series;
 import org.jfree.data.xy.XYSeries;
 import org.jfree.data.xy.XYSeriesCollection;
+import org.jfree.ui.RectangleEdge;
  * See main() for command-line arguments
@@ -54,7 +56,8 @@
   static Double ymin = null;
   static Double ymax = null;
-  static boolean withLegend = true;
+  static boolean legendEnabled = true;
+  static String legendPosition = null;
   static List<XYTextAnnotation> notes =
       new ArrayList<XYTextAnnotation>();
@@ -195,7 +198,7 @@
     JFreeChart chart =
       ChartFactory.createXYLineChart
       (title, xlabel, ylabel, collection,
-       PlotOrientation.VERTICAL, withLegend, false, false);
+       PlotOrientation.VERTICAL, legendEnabled, false, false);
     setupPlot(chart, collection);
@@ -254,7 +257,7 @@
   private static void setupPlot(JFreeChart chart,
-      XYSeriesCollection collection)
+                                XYSeriesCollection collection)
   throws UserInputException
     XYPlot plot = chart.getXYPlot();
@@ -280,6 +283,8 @@
     for (XYTextAnnotation note : notes)
       plot.addAnnotation(note);
+    placeLegend(chart);
   static void setAxes(XYPlot plot)
@@ -353,6 +358,27 @@
       ("Invalid axis.y type: " + axis_y_type);
+  static void placeLegend(JFreeChart chart)
+  throws UserInputException
+    if (legendPosition == null) return;
+    LegendTitle legend = chart.getLegend();
+    if (legendPosition.equals("right"))
+      legend.setPosition(RectangleEdge.RIGHT);
+    else if (legendPosition.equals("left"))
+      legend.setPosition(RectangleEdge.LEFT);
+    else if (legendPosition.equals("top"))
+      legend.setPosition(RectangleEdge.TOP);
+    else if (legendPosition.equals("bottom"))
+      legend.setPosition(RectangleEdge.BOTTOM);
+    else
+      throw new UserInputException
+      ("Invalid legend position: " + legendPosition);
        Various plot properties.  All are currently optional
@@ -403,7 +429,8 @@
       bw = Boolean.parseBoolean(tmp);
     tmp = properties.getProperty("legend.enabled");
     if (tmp != null)
-      withLegend = Boolean.parseBoolean(tmp);
+      legendEnabled = Boolean.parseBoolean(tmp);
+    legendPosition = properties.getProperty("legend.position");
     tmp = properties.getProperty("axis.x");
     if (tmp != null)
       axis_x_type = tmp;
More information about the Swift-commit
