[Swift-commit] r7890 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri May 30 18:25:27 CDT 2014
Author: hategan
Date: 2014-05-30 18:25:27 -0500 (Fri, 30 May 2014)
New Revision: 7890
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/While.java
Log:
fixed thread id issue in iterate() which can cause duplicate mapping errors
Modified: trunk/src/org/griphyn/vdl/karajan/lib/While.java
--- trunk/src/org/griphyn/vdl/karajan/lib/While.java	2014-05-30 04:19:02 UTC (rev 7889)
+++ trunk/src/org/griphyn/vdl/karajan/lib/While.java	2014-05-30 23:25:27 UTC (rev 7890)
@@ -12,6 +12,7 @@
 import java.util.LinkedList;
 import java.util.List;
+import k.rt.KRunnable;
 import k.rt.SingleValueChannel;
 import k.rt.Stack;
 import k.thr.LWThread;
@@ -80,42 +81,55 @@
         int i = thr.checkSliceAndPopState();
         SingleValueChannel<Object> next = (SingleValueChannel<Object>) thr.popState();
         List<RefCount> drefs = (List<RefCount>) thr.popState();
+        LWThread thr2 = (LWThread) thr.popState();
         Stack stack = thr.getStack();
         try {
-            switch(i) {
-                case 0:
-                    drefs = RefCount.build(stack, srefs);
-                    var.setValue(stack, NodeFactory.newRoot(Field.GENERIC_INT, 0));
-                    c_next.create(stack);
-                    RefCount.incRefs(drefs);
-                    next = (SingleValueChannel<Object>) c_next.get(stack);
-                    if (tracer.isEnabled()) {
-                        tracer.trace(thr, unwrap(next));
-                    i++;
-                case 1:
-                    while (true) {
-                        body.run(thr);
-                        if (next.isEmpty()) {
-                            // must do this twice since the closeDataSet calls
-                            // inside the iterate won't be called if the iterate
-                            // condition is true
-                            RefCount.decRefs(drefs);
-                            break;
-                        else {
+            out:
+                while(true) {
+                    switch(i) {
+                        case 0:
+                            drefs = RefCount.build(stack, srefs);
+                            var.setValue(stack, NodeFactory.newRoot(Field.GENERIC_INT, 0));
+                            c_next.create(stack);
-                        Object val = next.removeFirst();
-                        var.setValue(stack, val);
+                            next = (SingleValueChannel<Object>) c_next.get(stack);
+                            if (tracer.isEnabled()) {
+                                tracer.trace(thr, unwrap(next));
+                            i++;
+                        case 1:
+                            thr2 = thr.fork(new KRunnable() {
+                                @Override
+                                public void run(LWThread thr) {
+                                    body.run(thr);
+                            i++;
+                            thr2.start();
+                        case 2:
+                            thr2.waitFor();
+                            if (next.isEmpty()) {
+                                // must do this twice since the closeDataSet calls
+                                // inside the iterate won't be called if the iterate
+                                // condition is true
+                                RefCount.decRefs(drefs);
+                                break out;
+                            else {
+                                RefCount.incRefs(drefs);
+                            Object val = next.removeFirst();
+                            var.setValue(stack, val);
+                            i = 1;
         catch (Yield y) {
+            y.getState().push(thr2);
             y.getState().push(drefs);
             y.getState().push(next);
             y.getState().push(i);
