[Swift-commit] r7885 - in trunk: bin docs/userguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Thu May 29 11:41:17 CDT 2014
Author: davidk
Date: 2014-05-29 11:41:17 -0500 (Thu, 29 May 2014)
New Revision: 7885
Modified:
   trunk/bin/swiftrun
   trunk/docs/userguide/configuration
Log:
Document and allow property file.gc.enabled
Modified: trunk/bin/swiftrun
--- trunk/bin/swiftrun	2014-05-29 09:21:53 UTC (rev 7884)
+++ trunk/bin/swiftrun	2014-05-29 16:41:17 UTC (rev 7885)
@@ -71,6 +71,7 @@
    'clustering.queue.delay'          => 'clustering.queue.delay',
    'config.rundirs'                  => 'config.rundirs',
    'execution.retries'               => 'execution.retries',
+   'file.gc.enabled'                 => 'file.gc.enabled',
    'foreach.max.threads'             => 'foreach.max.threads',
    'kickstart.enabled'               => 'kickstart.enabled',
    'kickstart.always.transfer'       => 'kickstart.always.transfer',
Modified: trunk/docs/userguide/configuration
--- trunk/docs/userguide/configuration	2014-05-29 09:21:53 UTC (rev 7884)
+++ trunk/docs/userguide/configuration	2014-05-29 16:41:17 UTC (rev 7885)
@@ -343,6 +343,14 @@
 |The number of time a job will be retried if it fails (giving a
  maximum of 1 + execution.retries attempts at execution)
+|file.gc.enabled
+|true, false
+|true
+|Files mapped by the concurrent mapper (i.e. when you don't
+ explicitly specify a mapper) are deleted when they are not
+ in use any more. This property can be used to prevent
+ files mapped by the concurrent mapper from being deleted.
 |foreach.max.threads
 |Positive integer
 |1024
