[Swift-commit] r7858 - branches/release-0.94/docs/siteguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon May 12 11:07:35 CDT 2014
Author: davidk
Date: 2014-05-12 11:07:35 -0500 (Mon, 12 May 2014)
New Revision: 7858
Modified:
   branches/release-0.94/docs/siteguide/blues
Log:
Fix names
Modified: branches/release-0.94/docs/siteguide/blues
--- branches/release-0.94/docs/siteguide/blues	2014-05-12 16:05:37 UTC (rev 7857)
+++ branches/release-0.94/docs/siteguide/blues	2014-05-12 16:07:35 UTC (rev 7858)
@@ -1,14 +1,10 @@
 Blues (x86 cluster)
-Fusion is a 310-node computing cluster for the Argonne
-National Laboratory community. The primary goal of the LCRC is to
-facilitate mid-range computing in all of the scientific programs of
-Argonne and the University of Chicago.
+Blues is a 310-node computing cluster for the Argonne
+National Laboratory community. This section will walk
+you through running a simple Swift script on Blues.
-This section will walk you through running a simple Swift script
-on Fusion.
 Requesting Access
 If you do not already have a Blues account, you can request one at
@@ -30,13 +26,13 @@
 SSH Keys
 Before accessing Blues, be sure to have your SSH keys configured correctly.
-SSH keys are required to access fusion. You should see information about
+SSH keys are required to access Blues. You should see information about
 this when you request your account. Email support at lcrc.anl.gov for
 additional help.
 Connecting to a login node
-Once your keys are configured, you should be able to access a Fusion login
+Once your keys are configured, you should be able to access a Blues login
 node with the following command:
