[Swift-commit] r7854 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Sun May 11 22:08:22 CDT 2014
Author: ketan
Date: 2014-05-11 22:08:21 -0500 (Sun, 11 May 2014)
New Revision: 7854
Modified:
   SwiftApps/swift-galaxy/swift/buildsite.sh
   SwiftApps/swift-galaxy/swift/swiftforeach.py
Log:
fixes in python and test for T
Modified: SwiftApps/swift-galaxy/swift/buildsite.sh
--- SwiftApps/swift-galaxy/swift/buildsite.sh	2014-05-11 23:09:31 UTC (rev 7853)
+++ SwiftApps/swift-galaxy/swift/buildsite.sh	2014-05-12 03:08:21 UTC (rev 7854)
@@ -116,10 +116,11 @@
 localhost )
 cat << EOF >> $wdir/pool.xml
 <pool handle="localhost">
-  <execution provider="coaster" jobmanager="local:local" />
+  <execution provider="local" />
   <profile namespace="karajan" key="jobThrottle">0.07</profile>
   <profile namespace="karajan" key="initialScore">10000</profile>
   <filesystem provider="local"/>
+  <profile namespace="swift" key="stagingMethod">local</profile>
   <workdirectory>/tmp/swift.work</workdirectory>
 </pool>
 EOF
@@ -129,10 +130,11 @@
 echo "defaulting to localhost"
 </pool>
 EOF
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.py
--- SwiftApps/swift-galaxy/swift/swiftforeach.py	2014-05-11 23:09:31 UTC (rev 7853)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.py	2014-05-12 03:08:21 UTC (rev 7854)
@@ -5,6 +5,7 @@
 import os
 import distutils.spawn
 import traceback
+import fnmatch
 def setwdir():
     return subprocess.check_output(["mktemp", "-d", "/tmp/swift-gal.XXXX"])
@@ -15,12 +16,12 @@
 def buildcfg(wdir):
     f=open(wdir+"/cf", 'w');
-    f.write('use.provider.staging=true')
-    f.write('wrapperlog.always.transfer=true')
-    f.write('execution.retries=0')
-    f.write('provider.staging.pin.swiftfiles=false')
-    f.write('sitedir.keep=true')
-    f.write('lazy.errors=false')
+    f.write("use.provider.staging=true\n")
+    f.write("wrapperlog.always.transfer=true\n")
+    f.write("execution.retries=0\n")
+    f.write("provider.staging.pin.swiftfiles=false\n")
+    f.write("sitedir.keep=true\n")
+    f.write("lazy.errors=false\n")
     f.close()
 # numeric range
@@ -50,6 +51,7 @@
             rstart = next(myargs)
             rend = next(myargs)
             stepsize = next(myargs)
+            n = (rend - rstart)/stepsize
         outloc = next(myargs)
         outlistfile = next(myargs)
@@ -70,11 +72,11 @@
     #workout the file array only if user adds args else make it blank
     if fileargs:
         if k_or_t == "swiftK":
-            filearrayexpr="file fileargs[] <fixed_array_mapper; files=\""+','.join(fileargs)+"\">;"
+            filearrayexpr="file fileargs[] <fixed_array_mapper; files=\""+','.join(fileargs)+"\">;\n"
         else: #T
             filearrayexpr="file fileargs[]="+str(fileargs)+";\n"
     else:
-        filearrayexpr="file fileargs[];"
+        filearrayexpr="file fileargs[];\n"
     # create outloc dir
     if not os.path.exists(outloc):
@@ -90,15 +92,19 @@
     #workout standard input file
     if stdin:
+        #print "stdin"
-            stdinfilexpr = "file stdinfile<"+stdin+">;"
+            #print "stdinK"
+            stdinfilexpr = "file stdinfile<"+stdin+">;\n"
         else:
-            stdinfilexpr = "file stdinfile = input("+stdin+");"
+            #print "stdinT"
+            stdinfilexpr = "file stdinfile = input("+stdin+");\n"
     else:
+        #print "no stdin"
-            stdinfilexpr = "file stdinfile<\"/dev/null\">;"
+            stdinfilexpr = "file stdinfile<\"/dev/null\">;\n"
         else:
-            stdinfilexpr = "file stdinfile = input(\"/dev/null\");"
+            stdinfilexpr = "file stdinfile = input(\"/dev/null\");\n"
     #Build Swift source code
@@ -107,29 +113,29 @@
         f.write("type file; \n")
-        f.write("app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[]){ \n")
-        f.write("    "+interpreter+" @_exec _i _stringargs @_fileargs stdout=@_out stderr=@_err; \n")
+        f.write("app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){ \n")
+        f.write("    "+interpreter+" @_exec _i _stringargs @_fileargs stdin=@_stdin stdout=@_out stderr=@_err; \n")
         f.write("}\n")
         f.write(stringarrayexpr)
         f.write(filearrayexpr)
-        f.write("file exec<'"+executable+"'>;\n")
+        f.write(stdinfilexpr)
+        f.write("file exec<\""+executable+"\">;\n")
         if range_or_list == "list":
-            f.write("file listfile<"+listfile+">;\n")
+            f.write("file listfile<\""+listfile+"\">;\n")
             f.write("string list[] = readData(listfile);\n");
             f.write("foreach l, i in list{\n")
             f.write("file out <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".out\")>;\n")
             f.write("file err <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".err\")>;\n")
-            f.write("(out,err) = anapp(exec, i, stringargs, fileargs, stdinfile\n");
         else:
             f.write("foreach i in ["+rstart+":"+rend+":"+stepsize+"]{\n")
             f.write("    file out <single_file_mapper; file=@strcat("+outloc+", '/', i, '.out')>;\n")
             f.write("    file err <single_file_mapper; file=@strcat('"+outloc+"', '/', i, '.err')>;\n")
-            f.write("    (out,err) = anapp(exec, i, "+stringargs+", "+",".join(fileargs)+");\n")
+        f.write("    (out,err) = anapp(exec, i, stringargs, fileargs, stdinfile);\n")
         f.write("}\n")
         #build site
@@ -137,7 +143,7 @@
             basedir=os.path.dirname(sys.argv[0])
         else:
             basedir='.'
-        print "%s %s %s" %(basedir, sites, wdir)
+        #print "%s %s %s" %(basedir, sites, wdir)
         subprocess.call([basedir+"/buildsite.sh", sites, wdir])
         #build config
@@ -187,12 +193,79 @@
     f.close()
+    #Invocation
+    if k_or_t == "swiftK":
+        #$swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
+        with open(logfile,"wb") as errfile:
+            exitcode=subprocess.check_call([swift, "-sites.file", wdir+"/sites.xml", "-tc.file", wdir+"/tc", "-config", wdir+"/cf", wdir+"/script.swift", swiftargs],stderr=errfile)
+        print exitcode
+    else:
+        #print "Invoking T"
+        #EXITCODE=0
+        if sites == "localhost":
+            print "localhost"
+            stc=distutils.spawn.find_executable("stc")
+            turbine= distutils.spawn.find_executable("turbine")
+            with open(logfile, "wb") as errfile:
+                exitcode=subprocess.check_call([stc, "-j", "$(\which java)", wdir+"/script.swift"], stderr=errfile)
+            if exitcode == 0:
+                    exitcode=subprocess.check_call([turbine, "-n", n, wdir+"/script.swift"], stderr=errfile)
+        elif sites == "Vesta":
+            print "vesta"
+        elif sites == "Mira":
+            print "mira"
+        else:
+            print "site not recognized"
+        #STC=$(\which stc)
+        ##echo "got stc" >> /tmp/status.txt
+        #turbine=$(\which turbine)
+        ##echo "got turbine" >> /tmp/status.txt
+        #$STC -j $(\which java) $wdir/script.swift 2>$logfile
+        ##echo "done running stc" >> /tmp/status.txt
+        ##echo $turbine -n $n $wdir/script.tcl "${swiftargs}" >> /tmp/status.txt
+        #$turbine -n $n $wdir/script.tcl "${swiftargs}" </dev/null
+        ##echo "done running turbine, for $n" >> /tmp/status.txt
+        #EXITCODE=$?
+        ##echo "exit code obtained" >> /tmp/status.txt
+        #"Vesta" )
+        #TURBINE_HOME=/home/wozniak/Public/sfw/turbine
+        #STC=/home/wozniak/Public/sfw/stc/bin/stc
+        #$STC -j $(\which java) -t checkpointing -r ${PWD} $wdir/script.swift 2>$logfile
+        #$TURBINE_HOME/scripts/submit/cobalt/turbine-cobalt-run.zsh -n $n -s $HOME/cf $wdir/script.tcl
+        #EXITCODE=$?
+        #"Mira" )
+        #TURBINE_HOME=/home/wozniak/Public/sfw/ppc64/turbine
+        #STC=/home/wozniak/Public/sfw/ppc64/stc/bin/stc
+        #$TURBINE_HOME/scripts/submit/cobalt/turbine-cobalt-run.zsh -n $n -i $HOME/prerun.sh -s $HOME/cf $wdir/script.tcl
+        #EXITCODE=$?
+        #esac
     #Populate output file
     outlist=subprocess.check_output(["find", outloc, "-type", "f", "-iname", "*.out"])
     f=open(outlistfile, "w")
     f.write(outlist);
     f.close()
-    #dum ditty dum ditty dum dum dum
 if __name__=='__main__':
     main()
